Speedo works 1/2 the time?
Old Sep 9, 2004 | 07:54 PM
thePHIG's Avatar
Default Speedo works 1/2 the time?
i just noticed today, that sometimes when i start moving from a stop the speedo remains at 0, no matter what the speed. but if i accelerate quickly it suddenly starts to work. this only happened a few times, i think it only happened from engine off to moving, not while stopped at a light or anything ( i don't remember for sure) im a little lost on this so any help is appreciated
Old Sep 10, 2004 | 01:06 PM
TxTuner
Guest
Posts: n/a
Default Re: Speedo works 1/2 the time? (thePHIG)
This sounds like simply a loose wire behind your guage cluster. Fix it if you want but just think... As long as your speedo works half the time, so does your odometer... Half the miles when you finally sell the car!!!
Old Sep 10, 2004 | 02:19 PM
pyrojeff's Avatar
Default Re: Speedo works 1/2 the time? (TxTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">This sounds like simply a loose wire behind your guage cluster. Fix it if you want but just think... As long as your speedo works half the time, so does your odometer... Half the miles when you finally sell the car!!! </TD></TR></TABLE>
The odometer will add in the miles.. can't trick it.
BTW TxTuner.. you're quite the post *****
Old Sep 10, 2004 | 02:48 PM
Schmitey's Avatar
Default Re: Speedo works 1/2 the time? (pyrojeff)
do a search on vehicle speed sensors, sounds like a likely culprit
Old Sep 10, 2004 | 04:29 PM
TxTuner
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyrojeff &raquo;</TD></TR><TR><TD CLASS="quote">The odometer will add in the miles.. can't trick it. BTW TxTuner.. you're quite the post ***** </TD></TR></TABLE>
Alright bitch, I have the same problem on mine and refuse to fix it for the simple fact that the odometer only reads when the speedometer reads.
Old Sep 10, 2004 | 07:20 PM
BlazeTeck2000's Avatar
from what i know its the speed sensor cause mi nes was doing the same thing when i changed it and worked fine
Old Sep 10, 2004 | 07:37 PM
1illAccord's Avatar
Default Re: Speedo works 1/2 the time? (BlazeTeck2000)
i had the same problem with mine... it is the speedo that reads the miles. the odometer wouldn't spin when i just sat at 0. but i just bought a new one. it's straight now. yessir. but at the time, people were telling me it was the speed sensor. so it wouldn't hurt to get that checked out as well.
Old Sep 10, 2004 | 08:04 PM
thePHIG's Avatar
actually i believe pyrojeff is right because i just reset my trip meter last night and it is currently at 5.4mi but w.e
back on track, i think it is the gage or cable cus on the freeway when i put it in cruise it keeps its speed so its not the vss(vehicle speed sensor), at least thats what I've read
Old Sep 10, 2004 | 08:06 PM
well then it might not be the speed sensor if your curise control works it could be the cable if not its the dash its self they are cheap on ebay
Old Sep 10, 2004 | 08:27 PM
pyrojeff's Avatar
Alright bitch, I have the same problem on mine and refuse to fix it for the simple fact that the odometer only reads when the speedometer reads. </TD></TR></TABLE>
While it may not appear to add mileage, once it is hooked up correctly again it will add in the mileage over time.
Old Sep 10, 2004 | 08:31 PM
TxTuner
Guest
Posts: n/a
Yeah well, as long as I don't hook it up till right b4 I sell, I'll be good
Old Sep 11, 2004 | 11:02 AM
Schmitey's Avatar
however that would be HIGHLY illegal, and if you tried to pull that crap on me i'd cut your ***** off
Old Sep 11, 2004 | 11:04 AM
TxTuner
Guest
Posts: n/a
Default Re: Speedo works 1/2 the time? (Schmitey)
Then don't buy my car And if you think you can take my *****... a US Marines *****... go ahead and try
Old Sep 22, 2004 | 09:00 PM
1illAccord's Avatar
While it may not appear to add mileage, once it is hooked up correctly again it will add in the mileage over time.</TD></TR></TABLE>
this i didnt know...my bad. i spoke too soon. =] woops.
Old Sep 22, 2004 | 09:26 PM
philadd's Avatar
Default Re: Speedo works 1/2 the time? (1illAccord)
what year accord is this?
Old Sep 28, 2004 | 11:10 AM
Cyphear's Avatar
As long as the VSS isn't hooked up it wont add miles to the odometer.
Old Sep 28, 2004 | 11:16 AM
fw190bvi's Avatar
Default Re: Speedo works 1/2 the time? (Cyphear)
happened on my car as well about 2 years ago.....needed new speedo and odometer + harness' and such......its kinda cool to look down and see only 14000miles on a 94.....
Old Oct 13, 2004 | 10:46 AM
EnKidu's Avatar
That is fucked up & being a marine does not mean ****.... I tap out marines all the time. They have limited hand to hand skills... maybe if you had a gun
virdizzeripsta
Jan 1, 2014 11:58 AM
civiccpedx
May 18, 2007 06:56 PM
snackpack
Dec 18, 2006 02:39 PM
axtran
May 28, 2006 09:11 PM
Maxime
Mar 23, 2006 08:25 PM
