Zc and Si tranny questions
Old Sep 9, 2004 | 06:24 PM
TougeCoupe's Avatar
Default Zc and Si tranny questions
i have a 88 sedan dx with the zc in it im getting ready to swap in a 91 si i tranny from a crx can i use my old axles from my dx tranny and also will i have to get a clutch that will fit the si tranny or get a zc clutch.
Old Sep 10, 2004 | 07:59 AM
tpr's Avatar
tpr
Default Re: Zc and Si tranny questions (Touge4G4D)
You can use the SI axles. You have to use the 91 SI clutch disc, pressure plate etc to match the transmission. Its a direct bolt up.
Old Sep 10, 2004 | 08:24 AM
crx_88_si's Avatar
Default Re: Zc and Si tranny questions (tpr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpr &raquo;</TD></TR><TR><TD CLASS="quote">You can use the SI axles. You have to use the 91 SI clutch disc, pressure plate etc to match the transmission. Its a direct bolt up.</TD></TR></TABLE>
good stuff! and yes, your DX axles will work fine.
Old Sep 10, 2004 | 09:21 AM
bambam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touge4G4D &raquo;</TD></TR><TR><TD CLASS="quote">i have a 88 sedan dx with the zc in it im getting ready to swap in a 91 si i tranny from a crx can i use my old axles from my dx tranny and also will i have to get a clutch that will fit the si tranny or get a zc clutch.</TD></TR></TABLE>
your question was about "zc and Si tranny"...
then you said can you use your old dx axles...
do you have a dx or zc tranny in your car now?
Old Sep 10, 2004 | 10:04 AM
crx_88_si's Avatar
Default Re: Zc and Si tranny questions (bambam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam &raquo;</TD></TR><TR><TD CLASS="quote">
Old Sep 13, 2004 | 02:03 PM
TougeCoupe's Avatar
i have a dx tranny now but since i cam use my dx axles all i need now are the 91 SI clutch disc, pressure plate etc to match the transmission. Right.
Old Sep 13, 2004 | 02:49 PM
Sikocivic's Avatar
Default Re: (Touge4G4D)
If you have a 88 DX tranny in your car now you have the odd # of splines. When you put the 91 Si tranny in it will not fit the clutch disc. You can do 1 of 2 things. You can use a 89 clutch disc and pressure(DX&Si are the same) or you can get a 90-91 flywheel and use the 90-91 clutch set-up. I would use the 90-91 flywheel with the 90-91 clutch because its a little bigger so it will hold a little more power.
ESP.net
May 31, 2007 07:39 PM
See Are X
13
Nov 22, 2006 05:47 PM
messeduprex
Mar 17, 2005 01:06 AM
crooked muffler
Aug 10, 2004 07:49 PM
91HATCH
Feb 28, 2002 08:40 PM
