b+m fpr how crappy is it?
Old Sep 9, 2004 | 04:46 PM
honda9369's Avatar
Default b+m fpr how crappy is it?
well i couldnt afford a better one so i got theb+m fpr and guage. so how shitty is this fpr. how long b4 it takes a crap
Old Sep 9, 2004 | 04:47 PM
Gesundheit's Avatar
Default Re: b+m fpr how crappy is it? (honda9369)
I have never had a problem with mine, and I have used it for years.
Old Sep 9, 2004 | 04:50 PM
honda9369's Avatar
Default Re: b+m fpr how crappy is it? (Crankdriven)
cool. thats what i wanted to here.
Old Sep 9, 2004 | 05:42 PM
gloryhog's Avatar
the only thing about that reg. is that if you put a bigger fuel pump on and it pushes the press. way up, (mine went from 40 psi to 56 psi just from putting a walbro high press. 255lph.) you cant adjust the press. lower than the factory spring .
Old Sep 9, 2004 | 05:49 PM
B18C1CYA's Avatar
Default Re: b+m fpr how crappy is it? (gloryhog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gloryhog &raquo;</TD></TR><TR><TD CLASS="quote">the only thing about that reg. is that if you put a bigger fuel pump on and it pushes the press. way up, (mine went from 40 psi to 56 psi just from putting a walbro high press. 255lph.) you cant adjust the press. lower than the factory spring . </TD></TR></TABLE> yup thats the downside
Old Sep 9, 2004 | 06:02 PM
honda9369's Avatar
Default Re: b+m fpr how crappy is it? (B18C1CYA)
well that sucks. it says that it can adjust from 25psi to 60. damn it.
Old Sep 9, 2004 | 06:04 PM
ATS*Mark's Avatar
OG triple OG
ive got a walbro 255 and my pressure with the b&m is 44..i didnt modify it either.....
p.s. you can drill a smal hole in the middle of your stock fpr to lower pressures.
Old Sep 9, 2004 | 07:53 PM
honda9369's Avatar
Default Re: b+m fpr how crappy is it? (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">ive got a walbro 255 and my pressure with the b&m is 44..i didnt modify it either.....
p.s. you can drill a smal hole in the middle of your stock fpr to lower pressures.</TD></TR></TABLE>
well i hope i dont have anymore problems. ive had to many already. so 44 is a good psi settings
Old Sep 9, 2004 | 07:58 PM
B18C1CYA's Avatar
well i have mine set at 41 psi static
Old Sep 9, 2004 | 08:20 PM
honda9369's Avatar
yea if i can turn it down that far.
Old Sep 9, 2004 | 11:44 PM
90civichbsi's Avatar
you can do this to it to solve the problem with a bigger fuel pump..... http://theoldone.com/articles/regulator/
Old Sep 9, 2004 | 11:47 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: b+m fpr how crappy is it? (90civichbsi)
In some test Ive seen the b&M not being a 1:1 ratio regulator. Maybe I had 2 bad ones, but I'd recomend a non adjustable stock one over a b&m. I just think they are garbage, but once again my opinion doesnt matter anymore.
art
Old Sep 9, 2004 | 11:48 PM
Mase's Avatar
Default Re: b+m fpr how crappy is it? (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote"> once again my opinion doesnt matter anymore.
anymore?
who are you, ive never heard of you or your opinions before.
welcome aboard newb
Old Sep 9, 2004 | 11:57 PM
honda9369's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">you can do this to it to solve the problem with a bigger fuel pump..... http://theoldone.com/articles/regulator/</TD></TR></TABLE>
thnks that helped alot. now i see the light,lol damn i didnt no u needed to cut the top of the stock fpr to but the b+m fpr on.
Old Sep 10, 2004 | 01:22 PM
NVturbo's Avatar
O.G. triple O.G.
Hey...if the B&M unit doesn't cut it for you...try using an Aeromotive unit. I have it on my setup (purchased from Summit Racing) and it works fine. It's adjustable from 35-70psi and it has a ratio of 1:1. It does cost more than the B&M but in my opinion it is a better component. Plus, it holds better pressure. Had mine for over a year now and not a problem....knock on wood!!
Old Sep 10, 2004 | 01:26 PM
dc2legend's Avatar
Default Re: b+m fpr how crappy is it? (Mase)
I hope that was sarcasm . Anywho, my cousin has a B&M and is having trouble getting his fuel pressure low enough, 255 intank btw...
Old Sep 10, 2004 | 01:31 PM
honda9369's Avatar
well ive been every where looking for a .036 diameter drill bit and cant find one. would a 1/16 bit be to much. its the smallest i could find. ive been to home depot,lowes,and a parts store.
Old Sep 10, 2004 | 02:21 PM
mchuang's Avatar
I got mine 2 years ago and still do what it is suppose to. My liquid filled guage went out before my B & M regulator.
Old Sep 10, 2004 | 02:35 PM
Sprockets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda9369 &raquo;</TD></TR><TR><TD CLASS="quote">
well ive been every where looking for a .036 diameter drill bit and cant find one. would a 1/16 bit be to much. its the smallest i could find. ive been to home depot,lowes,and a parts store. </TD></TR></TABLE>
You have a PM. Otherwise, you need to check the Dremel section for the small bits.
Old Sep 10, 2004 | 02:42 PM
honda9369's Avatar
Default Re: b+m fpr how crappy is it? (B16A Grenade)
i looked at the dremmels,there is nothing that small
Old Sep 10, 2004 | 06:00 PM
honda9369's Avatar
Old Sep 10, 2004 | 06:16 PM
kappa12's Avatar
To find a drill bit that small, you have to go to a hobby shop. That's the only place that'll have them. You'll have to buy a Dremel accessory that'll allow you to hold a bit that small as well.
If you do drill it out, be sure not to do more than 0.035". I did mine more than that and it completely fucked up my fpr. It was totally useless. Just so you know, my tuner said that the "drilling it out" trick is a bunch of bullshit and that I should basically take theoldone.com out of my Favorites Good luck with whatever you do.
Josh
Old Sep 10, 2004 | 06:52 PM
Sprockets's Avatar
This is what I used. It's very close:
http://www.dremel.com/productd...66666
1/32 = .03125
Old Sep 10, 2004 | 07:34 PM
Tchleung's Avatar
Default Re: b+m fpr how crappy is it? (kappa12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kappa12 &raquo;</TD></TR><TR><TD CLASS="quote">my tuner said that the "drilling it out" trick is a bunch of bullshit and that I should basically take theoldone.com out of my Favorites Good luck with whatever you do.
Josh
Too bad that drillnig it DOES work if you do it properly. Offset towards the bototm, and at an angle.
Old Sep 10, 2004 | 10:39 PM
honda9369's Avatar
Default Re: b+m fpr how crappy is it? (Tchleung)
ill look around for that dremmel piece
