Brakes went - any ideas on what happened?
Old Sep 9, 2004 | 03:51 PM
hahahahhah's Avatar
Default Brakes went - any ideas on what happened?
Ok, so last night I was driving right, and some IDIOT decided to cut me off... so as usual I slammed on my brakes. Only problem was when I did so, after about a 1/4 of a second at full pedal pressure I heard a bang/pop. I lost pedal pressure and the car wouldn't stop under normal braking conditions, so I had to use the e-brake for the remainder of my trip. Now, the pedal falls all the way to the floor and I can still hear the 'hiss' of the pedal when I press/depress (booster). Any ideas of what it could be? I'm going to go out in a bit here and work my way back from the proportioning valve and see what's up. Maybe it was a line? OH yea, other weird thing too is that my e-brake warning light kept coming on everytime I pressed the brake pedal down like 20 mins before my brakes went. Now the e-brake light stays on and never shuts off.
Thanks,
-edmCRX
Old Sep 9, 2004 | 04:09 PM
shawn_crx's Avatar
Default Re: Brakes went - any ideas on what happened? (edmCRX)
you might want to check your rear brake boot. Probably pop or torn.
If you have drums on the rear
Old Sep 9, 2004 | 04:12 PM
LAMA's Avatar
Default Re: Brakes went - any ideas on what happened? (shawn_crx)
sounds to me like a line. beacuse of the pop and the ebrake light coming on piror to this.
Old Sep 9, 2004 | 04:36 PM
hahahahhah's Avatar
Default Re: Brakes went - any ideas on what happened? (LAMA)
hmm, k well I'll go investigate.. starting from the back and working my way forward.
I'll let you guys know what I find!
Thanks,
-edmCRX
Old Sep 9, 2004 | 04:41 PM
crxdx89's Avatar
well the light comes on when ur low on fluid or the brake is up (ebrake), it could also be the boot in the front caliper cuz the exact same thing that happened to me. just check everything starting from the calipers and drum master cylinder.
Old Sep 9, 2004 | 05:19 PM
green91's Avatar
id put some more fluid in the resevoir and pump the brakes.. see where it leaks from!
Alex E
Oct 1, 2022 09:40 AM
bads2k
May 7, 2012 04:44 PM
civic89si666
Jul 8, 2007 06:37 PM
Mr. Vapor
Feb 28, 2005 01:49 PM
99SlammedCivic
21
Apr 12, 2004 07:47 AM
