please help car wont start
Old Sep 9, 2004 | 02:42 PM
thunteg's Avatar
Default please help car wont start
well i took my cams out and put my stock cams back in and lined everything up top dead center well after tightining my timing belt i put everything back together and go to start it the motor turns over like it wants to start and keeps tarning like the im out of gas try to start any answers please?
thanks
Old Sep 9, 2004 | 03:00 PM
Jet Black's Avatar
Default Re: please help car wont start (thunteg)
Well short of telling you to check your timing, check the normal stuff
spark
gas
if you get both...well then it has to be a timing issue. Did you possible plug the distributor wires back in the wrong order?
Old Sep 9, 2004 | 03:09 PM
thunteg's Avatar
Default Re: please help car wont start (Jet Black)
no it is not the gas and it is not the distributer
Old Sep 9, 2004 | 03:43 PM
Jet Black's Avatar
well if you are sure you have spark and gas...did you check your compression?
Maybe you fucked up soemthing and your cams arent turning properly...givingbad compression and not allowing the engine to start.
Donno man
Old Sep 9, 2004 | 05:14 PM
DSR!'s Avatar
it could possibly be the ground, use a wire hooked up to the batterie's negative, and ground the motor with it, then try to start the car, this has happened to me bfore. if not then i don't know what it would be
Old Sep 10, 2004 | 04:03 AM
JimBlake's Avatar
Default Re: please help car wont start (DSR!)
You say you have gas... Do you mean gas is flowing thru the rail or do you know whether the injectors are actually firing??
Old Sep 10, 2004 | 11:54 AM
thunteg's Avatar
Default Re: please help car wont start (JimBlake)
gas is flowing checked that got new spark plugs just to make sure and my car still turns over but will not start on my safc it goes up to like 100 rpms but wont start
could this possibly be it?
when i had my cams at tdc i accidently left the little pin holders in there holding the cams still and then i tried to turn my lower part with the 19 and the belt kept overlaping so then i realized and took that off could that have messed anything up?
or would i have to take the bottum plastic off because where my cams were at tdc the bottum may not have been?
bomar
Sep 2, 2010 02:23 PM
vtecsi00
10
Feb 25, 2008 06:44 PM
Auby
Jan 18, 2007 07:26 AM
RenoRacing
Mar 29, 2003 09:50 PM
KooK
Apr 12, 2002 08:27 AM
