sleeve saver
Old Sep 9, 2004 | 01:49 PM
primeredbeast's Avatar
Default sleeve saver
Are sleeve savers good for running a gsr with type r pistons ?
Old Sep 9, 2004 | 03:10 PM
Tweakmeister's Avatar
Default Re: sleeve saver (primeredbeast)
they're crap and will likely cause hot spots/warp the factory sleeves.
keep the stock sleeves, the metal is superior for wear (life) of your rings, but remove the block and have it rehoned before you put in the new pistons (the block MUST be removed to get it done right).
I don't like replacement sleeves because the metal isn't as good for longevity of the motor, but most people don't run their cars over 100k anyway without blowing it up, so do what you want.
90CB7EX
Oct 22, 2016 12:33 AM
h22apwrd95
Nov 10, 2007 10:30 PM
H23vtecEG
Feb 12, 2003 10:05 PM
fe519
Nov 11, 2002 01:23 PM
Beast53568
Aug 5, 2002 11:05 PM
