Accord Type R CAMs
Old Dec 7, 2001 | 01:47 PM
hungy's Avatar
Default Accord Type R CAMs
Does anyone know if these are better than the Prelude Type S cams and how much better if so? Anyone know where to get these?
Old Dec 7, 2001 | 02:14 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: Accord Type R CAMs (hungy)
Not for certain, you can get them in Europe I bet. Why not just get different aftermarket cams here? Like the AEM or something..
Old Dec 7, 2001 | 04:26 PM
SOHCArchangel's Avatar
Default Re: Accord Type R CAMs (ForcedAccord)
aem doesnt make cams, try crower, or even a regrind
Old Dec 7, 2001 | 05:37 PM
Nick M's Avatar
Default Re: Accord Type R CAMs (SOHCkordVTEC)
Look over in the Prelude forum, there are quite a few threads about cams, jun and crower.
Old Dec 10, 2001 | 11:37 AM
HondaNewbie's Avatar
Default Re: Accord Type R CAMs (Hondasport94)
I thought AEM made cam gears?
Old Dec 10, 2001 | 02:26 PM
ArchAngel Sabastian's Avatar
New User
Default Re: Accord Type R CAMs (HondaNewbie)
cam gears but not cams
Old Dec 15, 2001 | 03:50 PM
Default Re: Accord Type R CAMs (Sabastian)
what's the difference? I know there is one but I'm not sure what it is...explain to da newbie please
Old Dec 15, 2001 | 06:04 PM
robot punch's Avatar
cams are the actual shafts that turn and raise and lower the valves, cam gears are the gears that turn the cams, right?
Old Dec 17, 2001 | 08:20 AM
Default Re: Accord Type R CAMs (robot punch)
I see...finally know what cams do, thanks!
Old Dec 17, 2001 | 08:24 AM
urbanlegend21's Avatar
New User
ladies and gentlemen we have a winner..............
wonder what the j-spec cam would do?
Old Dec 17, 2001 | 07:24 PM
4doorH22's Avatar
To be ****, which I mostly am, camshafts are the shafts whose cam lobes (well the "lobes" are the actual cams... "an eccentric or multiply curved wheel mounted on a rotating shaft, used to produce variable or reciprocating motion in another engaged or contacted part"...) rotate and push on rocker arms which in turn raise and lower the valves… and cam gears (aka cam timing sprockets) turn the camshafts.
Old Dec 17, 2001 | 08:20 PM
smokin rubber's Avatar
Default Re: Accord Type R CAMs (4doorH22)
Dave, you forgot to mention that the cam gear or sproket connects the cam or cams to the connecting rod by means of the timing belt.
Old Dec 17, 2001 | 08:21 PM
4doorH22's Avatar
Default Re: Accord Type R CAMs (smokin rubber)
errrr crank shaft?
Old Dec 17, 2001 | 08:24 PM
Mike P.'s Avatar
25 Year Member
the foot bone's connected to the....ankle bone. The ankle bone's connected to the...shin bone. The shin bone's connected to the knee bone...
Old Dec 17, 2001 | 08:36 PM
errrr crank shaft?
doh is that what its called
Old Dec 18, 2001 | 05:24 AM
h22a7 is the code for the type-r motor, and it is seriously hard to find
Kelzendless
Feb 19, 2014 05:14 PM
threehonda
K Series
Dec 20, 2009 06:37 PM
twiztid00002
Feb 5, 2009 12:01 PM
c1civic
Sep 20, 2003 11:17 AM
86CRXSi
Jun 10, 2002 06:13 PM
