94 Accord LX - power window concern
Old Sep 9, 2004 | 12:30 PM
otter1's Avatar
Default 94 Accord LX - power window concern
I have a 94 4 dr. Accord LX with a stalled driver's side power window. The window is in the down position and will not travel up. Before becoming terminal, the window was demonstrating slower up travel. All other windows work fine.
I have checked the fuse - OK. I then bought (later returned) a stock replacement motor/regulator assy, plugged it into the existing harness - prior to attempting installation - and witnessed the exact same performance (none), the slide would move in the down direction, however, there was no action in the up direction. I then suspected the power window switch assembly, picked up a salvaged unit, quickly replaced it, activated the switch, and once again experienced the same condition. Since I believe the odds of the salvaged switch experiencing the same fault (the window on the salvaged vehicle was in the up position) as mine were extremely low, I'm now suspecting the harness connector leading in the switch. Does anyone have any experience/thoughts/suggestions on next steps? Thanks...
Old Sep 9, 2004 | 02:09 PM
TxTuner
Guest
Posts: n/a
Default Re: 94 Accord LX - power window concern (otter1)
Open up the door and take a peak Look for a broken cable, the window off the track, or a fried regulator.
Czapsiu
Jun 9, 2018 07:54 AM
Hawaii Da9
Jan 16, 2012 06:19 AM
Ttlogan
May 25, 2009 10:55 AM
otter1
Sep 9, 2004 01:34 PM
