LS Vtec VS GSR which car have more power??
Old Sep 9, 2004 | 12:15 PM
Dc4turbo408's Avatar
Default LS Vtec VS GSR which car have more power??
LS vtec against a gsr which car will have more power and why?
Old Sep 9, 2004 | 12:17 PM
PlastikOwl
Guest
Posts: n/a
Default Re: LS Vtec VS GSR which car have more power?? (LsvtecBoi408)
whoever gets to 3rd gear first yo! m4d tIzzzIgHT!!!
Old Sep 9, 2004 | 12:23 PM
mystikteg92's Avatar
Default Re: LS Vtec VS GSR which car have more power?? (PlastikOwl)
it all depends on how well the ls/vtec is built
if ur talkin about doin a swap i would go with the gsr for reliability
ive heard of lsvtecs smoking type-r's tho, but ive heard of them gettin raped by Si's so it all depeneds on the quality of the build
Old Sep 9, 2004 | 12:27 PM
Phatch99's Avatar
bump cause i would like to know also... stock lsvtec i/h/e vs. gsr i/h/e
Old Sep 9, 2004 | 12:37 PM
DSR!'s Avatar
Default Re: LS Vtec VS GSR which car have more power?? (Phatch99)
It all depends on the driver. if the driver knows his car, then he would definately have the advantage. To my knowledge the LS Vtec should pull on the GSR because LS crankshaft will give the car more pull in the beginning(torque). I've "heard" of LS Vtec pulling type r's too, but i've never actually seen that happen
Old Sep 9, 2004 | 12:46 PM
ProJectCvic's Avatar
i don't think you know what ls/vtec is really. A properly built ls/vtec IS NOT STOCK by any means. It must have proper gsr/itr oil pump, aftermarket head bolt, aftermarket cams or oem ctr/itr, different Ecu combination, some sort of fuel management...etc. It is a combination of items to make the build successful in terms of power and reliablity. Also, it would be a waste of an ls/vtec build if the compression was not bump up.
There are many factors that affect a compression btw the two car you talking about. YES, LS/Vtec HAVE THE POTENTIAL to overpower the stock gsr or itr..no joke. If you taking about slapping an vtec head on an ls block and that is stock to you....then no, it will not have more horsepower or reliablity as a gsr.
Old Sep 9, 2004 | 12:49 PM
IntegraBoy04's Avatar
Default Re: LS Vtec VS GSR which car have more power?? (ProJectCvic)
I think the most power would come out of SEARCHING!!!!!!
Old Sep 9, 2004 | 12:50 PM
Default Re: LS Vtec VS GSR which car have more power?? (IntegraBoy04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">I think the most power would come out of SEARCHING!!!!!!</TD></TR></TABLE>
Nicely Put hahahaha
Old Sep 9, 2004 | 12:59 PM
Fullthrottlegsr's Avatar
ls/vtec is slow...i smoked one with my i/h/e LS..hahah....dude prob just slap on the head and using ls tranny.
Old Sep 9, 2004 | 01:09 PM
sPaRk'iT's Avatar
I say if the LsVtec was built right, it would be faster then gsr/itr, but it all depend on the driver too as well.
Old Sep 9, 2004 | 01:25 PM
W.O.P.'s Avatar
Default Re: LS Vtec VS GSR which car have more power?? (sPaRk'iT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk’iT &raquo;</TD></TR><TR><TD CLASS="quote">I say if the LsVtec was built right, it would be faster then gsr/itr, but it all depend on the driver too as well.</TD></TR></TABLE> good answer
Old Sep 9, 2004 | 01:35 PM
steven975's Avatar
Default Re: LS Vtec VS GSR which car have more power?? (1quickLS)
tranny ratios come into play, as well, and the GSR has an advantage.
The low end torque from the LS block is minimal and will never be an advangage in a straght line race as a GSR can launch at &gt;4K.
Old Sep 9, 2004 | 02:28 PM
Jet Black's Avatar
By making an LS VTEC you are trying to build a GSR / TypeR engine.
You'll get the advantage of shorter runners on the b16 IM if you use that head btu aside from that, part for part GSR should allmost allways be just as powerful if not more than the LS VEC.
This is not because LS VTEC is a bad idea, but you are trying to build a b18C engine with parts that arent ment to go together. Unless you can achieve the precision done by honda, your engine will not be a b18C and consequently will never be as well tuned. Now, if you start adding parts to your LS VTEC, yes you can make it more powerful, but then add the same parts to the GSR engine before you compare.
Yes the LS has a better crank-rod ratio for low end torque, but this ratio isnt designed for high rpms, so what advantage you'd gain low end you'd probably loose something high end, since a gsr will allways stay above 5000RPM throughout the 1/4 mile (appart from the launch), the LS VTEC is at a loss at this point, it simply cannot have the "rev happy" aspect the b18c engines do, due to its geometry.
As far as I know LSVTEC is a basically a poor mans GSR / ITR engine.
Old Sep 9, 2004 | 02:37 PM
Rod.'s Avatar
Default Re: LS Vtec VS GSR which car have more power?? (Jet Black)
why do people ask these questions
Old Sep 9, 2004 | 02:55 PM
Jet Black's Avatar
Default Re: LS Vtec VS GSR which car have more power?? (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">why do people ask these questions</TD></TR></TABLE>
n00bs?
Old Sep 9, 2004 | 05:14 PM
shamoo's Avatar
Will you make something up for me please?
Seriously!
Assuming both are built exactly the same, what do you think? A GSR has Vtec. An LS/Vtec has Vtec and the slightly larger displacement. What do you think the answer will be?
I don't think the original poster needs all the details about the driver or how the motor is built.. Basically the simple answer is above.
Old Sep 9, 2004 | 06:58 PM
YoungOne's Avatar
ls vtec but not as reliable. higher compression with the vtec head, the clearance is lower...it is belived to be somewhere around 11:1.
JesseBizz
19
May 21, 2009 05:49 PM
CR3X
Oct 26, 2007 05:43 PM
JDM-Rota
Aug 5, 2005 08:35 PM
lemongreenhatch
Jun 22, 2004 05:02 PM
lemongreenhatch
Jun 22, 2004 04:49 PM
