would this be a good purchase
Old Sep 9, 2004 | 11:56 AM
DarkBB4's Avatar
Default would this be a good purchase
Built H22a Head Crower stage 2 camshafts
Crower cam gears, Crower titanium valve springs and retainers, Crower SS valves, Port n' polished to gaskets, all new seals and seats. BO
i have a 95 prelude vtec with 129 k miles... i/h/e vafc 2, exdedy clutch adn jun flywheel?
i ran a 15.0... what could this bring me down to? along with tuing of the vafc?
Old Sep 9, 2004 | 12:11 PM
bigislandracing's Avatar
Default Re: would this be a good purchase (DarkspeedVtec95)
what kind of i/h/e do you have? those cams are advertised to make 12-15 hp on there website, along with the port n polish it should be a little more, but on stock compression id hope for 15 hp best, if you havea good header and intake manifold you may pick up some more hp then that..... depending on the car/driver/tires/track conditions you should hopefully be able to lower your et. .5-.8 seconds... just my personal experience.....
Old Sep 9, 2004 | 12:22 PM
94vtecmn's Avatar
Default Re: would this be a good purchase (bigislandracing)
Upgrading to the above mentioned head (Crower Stage 2 cams and valve train) along with Type-S pistons .25 over sized, 11:1 pistons, I made a solid 20+whp if that gives you any indication.
Old Sep 9, 2004 | 01:58 PM
DarkBB4's Avatar
Default Re: would this be a good purchase (94vtecmn)
so worth it.. or Nitrous?
I have apexi Cold air intake ( custom)... RSR 2.25 exhaust.. and a dc style header
Old Sep 9, 2004 | 02:58 PM
LudaMan's Avatar
Look what I can do!
how's your RS-R exhuast treatin ya? that was one of the brands i was considering
Old Sep 9, 2004 | 04:42 PM
DarkBB4's Avatar
Default Re: would this be a good purchase (LudaMan)
its quiet, but doesn't sound THAT good.. i gues i like the "ricier" apexi n1 sound...
My mufflers for trade
Old Sep 9, 2004 | 05:44 PM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkspeedVtec95 &raquo;</TD></TR><TR><TD CLASS="quote">so worth it.. or Nitrous?
I have apexi Cold air intake ( custom)... RSR 2.25 exhaust.. and a dc style header</TD></TR></TABLE>
Man, you can't compare this at all to Nitrous. It'd cost you 5 bucks to gain 20whp w/ nitrous and $3k all motor.
Depends on what you want and what you want it for.
Old Sep 9, 2004 | 08:40 PM
eLUDEnu
Guest
Posts: n/a
Default Re: would this be a good purchase (DarkKnight[DMD])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD &raquo;</TD></TR><TR><TD CLASS="quote">]
Depends on what you want and what you want it for.</TD></TR></TABLE>
YES SIR!!!!
Old Sep 9, 2004 | 08:58 PM
Fugun's Avatar
Default Re: would this be a good purchase (eLUDEnu)
true that, but honestly
i give more props to all motor cars than i do to bottle fed cars...
cars that boost, *shrugs* i give them props too but if you can build a all motor car that eats bottle fed and boosting cars, heh..
2 things..
1- you have a lot of money :-P
2- took a lot of time
i give mad props to those all motor racers out there droppin the fast **** times with BEEEG HP :-D
i personally am going all motor, slowly pulling my parts together, to drop it all in at one time...
its what you want out of the car, and how you want to achieve it.
Old Sep 10, 2004 | 02:52 AM
DarkBB4's Avatar
Default Re: would this be a good purchase (Fugun)
yea i mean... if i had morem oney then id def go ALL mota.... but considering im 16 with a part time job as a pizza cook makin 5.15 an hour.. I dont think i have 3k to spend
I think ill run a compresssion test and then get some nawzzz
Old Sep 10, 2004 | 03:56 AM
Adam.'s Avatar
Just make sure you get your nawzzz tuned
Or one night your car will go boom.
Old Sep 10, 2004 | 05:00 AM
94vtecmn's Avatar
Just my opinion, but if you cannot afford to go all motor, you most likely cannot afford to go Nitrous. It's not exactly cheap, and it raises holy hell on your motor. If your not racing, just enjoy what you have, start saving, keep researching, and set a goal. If your 16 like you say, all you want to do is go faster, I know, but take your time. Going faster at 16 is not cheap, unless you have parents with deep pockets.
I know, I've taken this away from the point, but that is my point.
Modified by 94vtecmn at 9:45 AM 9/10/2004
Old Sep 10, 2004 | 05:40 AM
Kal's Avatar
Kal
yep, 16 and going fast is a bad combination.
Old Sep 10, 2004 | 10:56 AM
DarkBB4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtecmn &raquo;</TD></TR><TR><TD CLASS="quote"> Going faster at 16 is not cheap, unless you have parents with deep pockets.
Modified by 94vtecmn at 9:45 AM 9/10/2004</TD></TR></TABLE>
yo i pay for everything.. car, gas mods, insurance.. all worked for
ANYWAYS.. im not a dumbass and dont race on teh street and ****
I like the track and i plan to become a better driver and have a faster car.. my best was a 15.3 and my brother raced once ( 20 yrs old) in my car and rana 15.2.. so i have work to do
JUST lookinb for another mod, and i think Nitrous might be the way to go... just olike a 35 or a 50 shot NOTHING MORE
Old Sep 10, 2004 | 03:32 PM
limpmode's Avatar
also remember a turboed 500 max hp 4 cyl car will be MUCH easier to drive around everyday than even a 350 hp N/A 4cyl car, but still be much faster at track day and whenever you need it. being 16 i would say a second car is out of the question too.
if you do go nitrous, make sure it cuts off before your rev limiter. otherwise start shoppin for new motors
Old Sep 10, 2004 | 04:12 PM
DarkBB4's Avatar
Default Re: would this be a good purchase (limpmode)
yea im kinda a newb to settin up nitrous, but i know that its the cheapest way to gain hp and to help ur 1/4 times....
would a 35 shot be worth it?
Old Sep 10, 2004 | 04:55 PM
Kal's Avatar
Kal
35 shot would not be worth it.
Old Sep 11, 2004 | 11:34 AM
limpmode's Avatar
Default Re: would this be a good purchase (Kal)
if properly done (get a kit) a stock H22a can take up to a 75 shot safely, but only use it when you need to.
Old Sep 11, 2004 | 02:47 PM
ludermark's Avatar
there is no reason for nitrous. save your money, because obviously
means that you wont be able to afford another car if for some reason nitrous messes you up.
good luck though, i hate nawzzz
Old Sep 11, 2004 | 03:09 PM
revlimitx04's Avatar
Default Re: would this be a good purchase (ludermark)
nos kills engines.... n/a most honorable then comes FI... Dont mess with nos, most likely your engine is gunna go boom.. expecially at 16.
If you want speed then sell that car and get a z28 or gt that will satisfy your low budget speed needs.
Old Sep 11, 2004 | 03:43 PM
LudeyKrus's Avatar
Default Re: would this be a good purchase (revlimitx04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revlimitx04 &raquo;</TD></TR><TR><TD CLASS="quote">nos kills engines.... n/a most honorable then comes FI... Dont mess with nos, most likely your engine is gunna go boom.. expecially at 16.
Wrong. (i'll be nice w/ this one)
Old Sep 11, 2004 | 05:57 PM
limpmode's Avatar
Default Re: would this be a good purchase (LudeyKrus)
nitrous kills engines when people don't know how to use it, or overuse it. i run N/A myself, but know people who spray on their drag cars. only seen one blow up, and it was cause something failed. but keep in mind these are custom set ups, so much more complicated too- more **** to go wrong.
kyle-Lst
Jun 6, 2007 11:23 AM
connvict
Jul 4, 2004 11:59 PM
h22 civic
Apr 8, 2004 12:31 PM
1fast5gp
Nov 26, 2002 10:01 PM
Y2K Si FBP
Jun 18, 2002 08:06 PM
