For those of you who pieced together your own kit
Old Sep 9, 2004 | 08:50 AM
Import_Fan's Avatar
Default For those of you who pieced together your own kit
Where did you get all of the correct sized piping? It seems easy enough to me to buy all the main components separately
Turbo, IC, Wastegate, BOV, Manifold, Injectors, Fuel Pump, Hondata
But to get the smaller pieces like pipes shaped correctly at the correct length and the assorted fitting and hoses, where did you get them?
Old Sep 9, 2004 | 08:55 AM
Integra_RS's Avatar
Some muffler shops can do it... my cat back is costing $191 installed & including muffler ;-)
flip1199's Avatar
Default Re: For those of you who pieced together your own kit (Import_Fan)
jcwhitney exhuast piping is where most people get the piping to make the i/c and d/p piping.
Old Sep 9, 2004 | 08:57 AM
DubyaAye's Avatar
Default Re: For those of you who pieced together your own kit (flip1199)
i got all my exhaust and ic piping from kteller.
Old Sep 9, 2004 | 09:06 AM
FOrSfEd's Avatar
Default Re: For those of you who pieced together your own kit (DubyaAye)
I usually find good deals with people selling the piping, but if I were to make my own I would def go through kteller.
Old Sep 9, 2004 | 10:27 AM
donkiman's Avatar
Default Re: For those of you who pieced together your own kit (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">I usually find good deals with people selling the piping, but if I were to make my own I would def go through kteller.</TD></TR></TABLE>
its not to tough to have a shop modify piping. and i got my full 2.5 inch exhaust no cat res or muffler shaped and welded for $150.
Old Sep 9, 2004 | 10:39 AM
MooreBoost's Avatar
Default Re: For those of you who pieced together your own kit (donkiman)
I just hacked up and welded an ebay CAI.
Old Sep 9, 2004 | 10:59 AM
stealthmode62's Avatar
Default Re: For those of you who pieced together your own kit (tegunderpressure)
For the exhaust I just took it to the exhaust shop. Too much of a chance for rattling or whatever on that side to try to do it myself.
For the charge pipes, I bought 3-4 2.5" U-bends, and then when I was at the exhaust shop (for the exhaust) I bought 5' or 2.5" straight piping from them. Take all of that home and start cutting up the ubends and tack welding were neccessary. You'll get it.
Old Sep 9, 2004 | 11:28 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DubyaAye &raquo;</TD></TR><TR><TD CLASS="quote">i got all my exhaust and ic piping from kteller.</TD></TR></TABLE>
DITTO
http://www.kteller.com
Old Sep 9, 2004 | 11:45 AM
PolyPill's Avatar
Default Re: For those of you who pieced together your own kit (xenocron)
I got mine from jegs, I don't recommend buying from them, my pipes were oval!!
Old Sep 9, 2004 | 12:02 PM
Import_Fan's Avatar
Wow thanks!!
I've read Honda-Tech and other sites for years now and this is first time I've heard of KTeller. Seems really good!! But now the hard part would be knowing what shapes to get and how many feet.
Old Sep 9, 2004 | 03:58 PM
T-RO's Avatar
If you can cut and weld just buy the Ubends from JCwitney
http://www.jcwhitney.com/webap...10101
Old Sep 9, 2004 | 04:13 PM
Ri5e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">I just hacked up and welded an ebay CAI.</TD></TR></TABLE>
Old Sep 9, 2004 | 04:42 PM
quik sol's Avatar
http://www.kteller.com for all piping
Old Sep 9, 2004 | 05:51 PM
B18C1CYA's Avatar
go on e-bay and search for a seller named the " ubendman" has good prices and can make just about anything you want
Old Sep 9, 2004 | 05:58 PM
HXMan's Avatar
http://www.burnsstainless.com/
Old Sep 9, 2004 | 06:00 PM
adseguy's Avatar
Default Re: For those of you who pieced together your own kit (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_Fan &raquo;</TD></TR><TR><TD CLASS="quote">Wow thanks!!
But now the hard part would be knowing what shapes to get and how many feet. </TD></TR></TABLE>
Your in luck I am exactly in that process right now. I am doing what everyone else said to do which is jcwhitney or kteller.com. I'm going to mock(sp) up the turbo, manifold, Wastegate, and IC. Then measure with a tape measure what exact pieces I need. Basically it's going to be a lot of U bends and some 90 degrees too. Yeah I'll have a little left over after it all, but it's a ton cheaper then a garage doin it (especially if it's 3" DP since most don't do that)!
Old Sep 11, 2004 | 11:41 PM
crex23's Avatar
Default Re: For those of you who pieced together your own kit (adseguy)
I have a 88 CRX with LS swap and want to go turbo. I priced a complete kit from a sponsor here on h-t for $3500 which I think is really high (for me at least). I can buy the main pieces (turbo, IC, manifold, etc) seperately for ~$1500. And I'll probably buy the piping from either jc or kteller, as yall suggested.
But where do you get all the other pieces from (like all the hardware, gaskets, and silicon pieces)?
I have never done a turbo before, and I'm kinda overwhelmed by everything.
BTW, sorry to jack the thread
Old Sep 11, 2004 | 11:46 PM
Ckjeepin's Avatar
Default Re: For those of you who pieced together your own kit (crex23)
there is a vendor i do believe that sells silicone hose clamps. If not try the forums on homemadeturbo.com
Old Sep 12, 2004 | 07:11 AM
sethm's Avatar
Default Re: For those of you who pieced together your own kit (Ckjeepin)
yeah his name is Stealthmode on homemadeturbo.com or you could try http://www.StealthmodePerformance.com
Old Sep 12, 2004 | 09:01 AM
b16ahybrid's Avatar
I've read Honda-Tech and other sites for years now and this is first time I've heard of KTeller. Seems really good!! But now the hard part would be knowing what shapes to get and how many feet. </TD></TR></TABLE>
You will just need to buy a few u-bends and mock it all up before cutting. get a rough estimimate of the lenght that you need cut it a little long then shave off any extra. Thats the easiest way of doing it.
Old Sep 12, 2004 | 10:49 AM
Blaze45's Avatar
Brrraaaap!
Default Re: For those of you who pieced together your own kit (b16ahybrid)
I got mine from my welder.... He had cheaper prices then anything that I could find online and plus I didnt have to pay for shipping or wait for them to come in!
Blaze
Old Sep 12, 2004 | 12:13 PM
plusONE jboy's Avatar
spoolin performance did my piping/install im sure if you wanted piping they could fab you some..
Old Sep 12, 2004 | 01:44 PM
cml64vr6's Avatar
Default Re: (j boy)
you can get piping from almost anywhere. hell ive probably got some 2.5" pipes laying around my garage somewhere. any exhaust shop can bend them if you cant
Old Sep 12, 2004 | 03:10 PM
xenocron's Avatar
Default Re: (vdubvr6)
http://www.partssystems.com/sh...TBOLT
Clamps are good and cheap from the above link.
I got a lot of rubber elbows and 45 bends from:
http://dnaparts.com/hoses.htm
http://dnaparts.com/airtoair.htm
When you call them on the phone, tell them you want dealer pricing...they are pretty cool guys to work with and the prices are definitely right
