blown gsr block.....got a good ls block where to start at?
Old Sep 9, 2004 | 04:23 AM
gulftiresinc's Avatar
Default blown gsr block.....got a good ls block where to start at?
blown gsr block got a ls block where to start at?
i got gsr bottem end (crank,rods,the main caps water pump the works just the blocks is messed up!!
i got a very good ls bottem end
i can also get type r pistons an rods where to start fellas????
thx
Old Sep 9, 2004 | 11:22 AM
Default Re: blown gsr block.....got a good ls block where to start at? (gulftiresinc)
Old Sep 9, 2004 | 11:58 AM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gulftiresinc &raquo;</TD></TR><TR><TD CLASS="quote">blown gsr block got a ls block where to start at?
thx</TD></TR></TABLE>
CTR Pistons! CTR's will yeild you higher compression than ITR's and make sure to use ARP rod bolts and replace all the bearings!
Old Sep 9, 2004 | 11:59 AM
Also what head will you be using, I assume GSR, right!
Old Sep 9, 2004 | 12:06 PM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
Default Re: blown gsr block.....got a good ls block where to start at? (hybrid_vtec)
using the GS-R crank in the LS block is not going to yeild you the benefits of an LS vtec but you're going to have to run the external oil line for vtec and you're not going to have oil squirters (which won't be necessary IF you get forged pistons) or a girdle
NSTY Z33's Avatar
CTR is said to have to much compression for street car. I honestly believe it said that many builders/machinists here in Florida and California say so. You want reliability/perfect standpoint for street compression, people love p30 slugs
EK FLY
Jan 4, 2006 06:17 PM
arielmalespin
Apr 27, 2005 11:24 AM
Who Said
Mar 8, 2003 06:38 AM
blmracing
Feb 25, 2003 10:15 PM
