Prelude injectors good for my set-up?
Old Sep 9, 2004 | 03:56 AM
sircrxracer's Avatar
Default Prelude injectors good for my set-up?
Was wondering I need to do some injectors and would like to use the Lude ones they seem to be good for cheap are they good enough for my set-up???
GSR block Pr3 pistons, ITR head ported, ported intake mani, getting when I do this I'm getting Skunk2 stage 2 cams, DC JDM header, I think 155 intank pump and STR fuel rail. Running about 12.1 compression
The head and intake mani is opened alot so do you think these injectors will be good enough? It's in a CRX non OBD so I can use low resistance injectors.
TIA Rob
Old Sep 9, 2004 | 07:53 PM
Circuit Star-29's Avatar
Default Re: Prelude injectors good for my set-up? (sircrxracer)
First of all...where does the extra compression come from? Your setup should only yeild about a 11:1 CR. The only way you'll see a 12:1 CR with your setup is with CTR piston or pistons of similar dome volume. The other thing you need to ask your self is what kind of tuning are you looking to have done and what are your goals as for power. I say using lude injectors is a good place to START!!! You might find a need for increasing the size slighty, maybe 310s or 370s... if your looking to get higher number down the line, you should think about that now.
To answer your question striaght up...You can start with them, but don't expect to squeeze alot of flow out of them.
Old Sep 9, 2004 | 11:15 PM
OLM-02R's Avatar
yeah prelude h22a injectors are ok...
1992-96 Prelude VTEC Peak and hold 345cc
Old Sep 10, 2004 | 04:06 AM
Default Re: Prelude injectors good for my set-up? (nathan atwell)
With out a shaved head it's 11.4 then I shaved head .33 thou don't ask........... I hit 195 with CTR cams so I'm hopping for 210 HOPE is the key word....... I'm limited to the FVC for now so that's what I will be tunning with...... the pump I'm getting is 190 intank.
Thanks Rob
Old Sep 10, 2004 | 06:37 AM
hype r 555's Avatar
I'm running prelude injector's in my R I'm puttin down 205whp+ w/ 12.5:1 n s2stg2 cams....u'll be fine...Prelude injectors are 310cc...ur straight
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathan atwell &raquo;</TD></TR><TR><TD CLASS="quote">First of all...where does the extra compression come from? Your setup should only yeild about a 11:1 CR. The only way you'll see a 12:1 CR with your setup is with CTR piston or pistons of similar dome volume. The other thing you need to ask your self is what kind of tuning are you looking to have done and what are your goals as for power. I say using lude injectors is a good place to START!!! You might find a need for increasing the size slighty, maybe 310s or 370s... if your looking to get higher number down the line, you should think about that now.
To answer your question striaght up...You can start with them, but don't expect to squeeze alot of flow out of them.</TD></TR></TABLE>
Old Sep 10, 2004 | 06:52 AM
NAstreetEH2
Guest
Posts: n/a
usdm obd1's are, right?
aren't obd2's like 345, or is that just the JDM ones?
Old Sep 10, 2004 | 07:46 AM
Default Re: Prelude injectors good for my set-up? (bb4lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4lude &raquo;</TD></TR><TR><TD CLASS="quote">I'm running prelude injector's in my R I'm puttin down 205whp+ w/ 12.5:1 n s2stg2 cams....u'll be fine...Prelude injectors are 310cc...ur straight
Thanks man that's what I wanted to hear Rob
Old Sep 10, 2004 | 08:42 AM
Used2beAb16's Avatar
OBD II h22 injectors are 280's. The SH injectors are 290's.
Old Sep 10, 2004 | 08:59 AM
hype r 555's Avatar
Default Re: Prelude injectors good for my set-up? (Used2beAb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 &raquo;</TD></TR><TR><TD CLASS="quote">OBD II h22 injectors are 280's. The SH injectors are 290's. </TD></TR></TABLE>
96-96 Prelude injectors are 310cc....I have them in my setup...And like i said before i'm down 205whp+ with higher compression and a 255 walbro fuel pump.
Old Sep 10, 2004 | 10:03 AM
hybrid_vtec's Avatar
Default Re: (NAstreetEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAstreetEH2 &raquo;</TD></TR><TR><TD CLASS="quote">usdm obd1's are, right?
aren't obd2's like 345, or is that just the JDM ones?</TD></TR></TABLE>
As far as I remember the OBD-1 injectors are 345cc and the OBD-II injectors are 270cc!
http://www.allmotorhonda.com/t...r.htm
Old Sep 12, 2004 | 07:19 AM
Rollo Lawson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sircrxracer &raquo;</TD></TR><TR><TD CLASS="quote">With out a shaved head it's 11.4 then I shaved head .33 thou </TD></TR></TABLE>
you have more than 12.0/1 c.r. from what i know, shaving your head .33" should give you pretty much 1 FULL point of compression. i think that you are in the 12.3x/1 c.r. just to let you know.
Old Sep 12, 2004 | 11:49 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Prelude injectors good for my set-up? (B16C1)
I'm running OBD1 Prelude injectors on my LSVTEC.. I like them.
Old Sep 13, 2004 | 06:07 AM
Default Re: Prelude injectors good for my set-up? (LSVTEC 91 Civic)
Running OBD-1 H22 injectors on my N/A LS!
Old Sep 15, 2004 | 04:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 &raquo;</TD></TR><TR><TD CLASS="quote">
you have more than 12.0/1 c.r. from what i know, shaving your head .33" should give you pretty much 1 FULL point of compression. i think that you are in the 12.3x/1 c.r. just to let you know.</TD></TR></TABLE>
That's what I thought...... I pulled the motor out and the head is off everything looks mint...... I'm claying the motor for my new cams Skunk2 stg 2 and degree everything then I will no how much I can move the cams on the dyno so I don't have clearance issues.
Thanks for all your help guys. Rob
1990_integra_DA9
Jun 13, 2008 09:22 PM
slow91crx
Jun 3, 2006 11:09 AM
damnecheck
Jan 25, 2005 12:37 PM
GapxGuy
Apr 25, 2004 01:21 PM
one_c18b
Apr 21, 2004 09:29 PM
