Pix of new RPS carbon fiber clutch for the B
Old Sep 8, 2004 | 10:37 PM
earl's Avatar
Default Pix of new RPS carbon fiber clutch for the B
Here is some pix of the new RPS carbon fiber twin disc clutch. We have been testing clutches for RPS this year and this model is the results of the R & D. I believe they are selling these units now. They have instant release at shifts of over 10,000 rpm. I hope RPS will add some tech to this post.
Old Sep 9, 2004 | 12:26 AM
FastEK9's Avatar
Default Re: Pix of new RPS carbon fiber clutch for the B (earl)
What are the prices on these earl?
Old Sep 9, 2004 | 12:27 AM
AspectIndustries's Avatar
Default Re: Pix of new RPS carbon fiber clutch for the B (FastEK9)
Yea, prices and specs would be awsome. Looks good.
Old Sep 9, 2004 | 12:46 AM
ninesecrx's Avatar
Default Re: Pix of new RPS carbon fiber clutch for the B (synik)
Retail price on this clutch is about $3,500 bucks. But if anyone would be interested, they can be had a little cheaper then what full retail is. This clutch is 100 percent fully rebuildable. Its a very nice peice and the pedal feels like stock. I would say it could be a very streetable clutch that would handle even full racecar HP.
TeStUdO's Avatar
im sure they are at least 1500 but they are a nice looking clutch
Old Sep 9, 2004 | 12:49 AM
ninesecrx's Avatar
Default Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">im sure they are at least 1500 but they are a nice looking clutch</TD></TR></TABLE>
Yes, quite a bit more then that. Carbon fiber is not a cheap material to make or use in this kind of app. The cure process takes a long time with multiple stages.
Old Sep 9, 2004 | 03:10 AM
Blind-Fashion's Avatar
I'm interested.
Old Sep 9, 2004 | 03:55 AM
BoostedsiR's Avatar
Default Re: (Blind Fashion)
wow
Old Sep 9, 2004 | 05:42 AM
Drag_On's Avatar
Racing is expensive :-(
Old Sep 9, 2004 | 05:56 AM
JDMCRX's Avatar
Default Re: (Drag_On)
**** thats a nice clutch. Bet who ever wants it is going to have to cut a nut or arm off for it.
Old Sep 9, 2004 | 06:02 AM
Ckjeepin's Avatar
Default Re: (JDMCRX)
3500 thats alot of money.. Outta my league
Old Sep 9, 2004 | 06:04 AM
b18bturbo's Avatar
Earl,
What makes this a preferred clutch over the tilton carbon. Both are exact same prices retail. I know the tilton clutch has been proven to work in many applications.
Old Sep 9, 2004 | 06:06 AM
done's Avatar
Default Re: (Ckjeepin)
How will this clutch compare to the tilton Carbon/Carbon..
and will this rps clutch, have the same type of bearing system, that tilton offers as extra..
Old Sep 9, 2004 | 06:39 AM
Boostage's Avatar
Default Re: (Jordo)
bump
Old Sep 9, 2004 | 06:42 AM
FOrSfEd's Avatar
Default Re: (Boostage)
Nice clutch but way out of my league, I think I will stick with the RPS stage 3
Old Sep 9, 2004 | 07:01 AM
Boostage's Avatar
Default Re: (FOrSfEd)
what part is carbon fibre. I really cant tell
Old Sep 9, 2004 | 07:14 AM
b18bturbo's Avatar
the pucks of the disc are carbon fiber. The disc can take extreme heat comapred to any type of sintered iron.
Old Sep 9, 2004 | 07:18 AM
done's Avatar
Default Re: (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">the pucks of the disc are carbon fiber. The disc can take extreme heat comapred to any type of sintered iron. </TD></TR></TABLE>
yes, rumor has it. the hotter it gets, the more it sticks..
Old Sep 9, 2004 | 07:26 AM
Boostage's Avatar
then if its the pucks that are CF how are they rebuildable?
Old Sep 9, 2004 | 07:48 AM
Ekasey's Avatar
Earl that looks really nice, you know what would look nicer?
A burns Stainless manifold on the new car! lol shhhhh
If i could afford it wow, but i went cheap and got the tilton twin disc setup
Old Sep 9, 2004 | 08:14 AM
Mikes01GSR's Avatar
Default Re: (eLusive ek4)
Earl is this RPS upgraded? I have a RPS Carbon / Carbon but it looks a little different, It's a bad *** clutch though I love it. The hotter it gets the more it
grips yet it is very easy on drivetrain parts.
Old Sep 9, 2004 | 09:04 AM
RPSPP's Avatar
Hi Everyone,
Thank you for your compliments on the RPS Twin Disc Carbon-Carbon clutch. This product has been proven to be the ultimate clutch for the higher HP community of cars such as the Supra, 3000 GT VR-4, and the 300ZXTT models. And now exceeding the technology beyond that is this clutch that Earl had taken picture of. The newest and the best clutch from RPS for your B-Series.
The highest technology known to man in friction surface is Carbon-Carbon. Carbon-carbon composites consist of highly-ordered graphite fibers embedded in a carbon matrix. C-C composites are made by gradually building up a carbon matrix on a fiber preform through a series of impregnation and pyrolysis steps or chemical vapor deposition. C-C composites tend to be stiffer, stronger and lighter than steel or other metals. The most important class of properties of carbon-carbon composites is their thermal properties. C-C composites have very low thermal expansion coefficients, making them dimensionally stable at a wide range of temperatures, and they have high thermal conductivity. C-C composites retain mechanical properties even at temperatures (in non-oxidizing atmospheres) above 2000°C. They are also highly resistant to thermal shock, or fracture due to rapid and extreme changes in temperature.
Our hard core clients who uses our C/C technology are racers that are utilizing this amazing break-through by doing 2nd gear burnouts, 2nd gear launches, line lock assisted launch with the clutch semi disengaged to load the engine to make positive boost 15~30 psi in 2nd gear!!! Others do 1st gear 7000+ RPM clutch dumps to get the clutch to slip for a fraction of a second for it not to break the tires loose. All on a 2 ton AWD car making 750+AWHP 200+ times at the track daily driven (3000GT-VR-4 Dynamic Racing), Supra 2JZ with 1200lbs of torque on a dyno slipping (Powerhouse/MVP), Viper GTS Supercharged cranking out 1000lbs of torque daily driven (Palo Castalano/ Heffner Performance) to name a few.
Old Sep 9, 2004 | 09:49 AM
Boostage's Avatar
Default Re: Pix of new RPS carbon fiber clutch for the B (RPSPP)
how are carbon pucks rebuildable?
Old Sep 9, 2004 | 09:55 AM
diputs's Avatar
Default Re: Pix of new RPS carbon fiber clutch for the B (Boostage)
The carbon pads are replaceable. Therefore, the clutch is rebuildable.
Old Sep 9, 2004 | 10:15 AM
Boostage's Avatar
Default Re: Pix of new RPS carbon fiber clutch for the B (diputs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diputs &raquo;</TD></TR><TR><TD CLASS="quote">The carbon pads are replaceable. Therefore, the clutch is rebuildable.</TD></TR></TABLE>
yeah but for how much?
