Intake Manifold Question?
Old Sep 8, 2004 | 09:37 PM
Lamska's Avatar
Default Intake Manifold Question?
Hey guys hoping you guys can solve or answer this question for me.
I just did a LS/VTEC swap to my Integra, motor is running great.
The specs are b16A head with LS bottom.
Just one problem though. I found out that I am running a OBD0 intake manifold with my OBD1 setup. What happens now is my car is ideling really high, b/c the idle control device on the OBD0 intake manifold does not fit my new setup. The car idels right now around 1500 rpms.
So my question to you guys is does a OBD0 Intake Manifold work with a OBD1/OBD2 LS/VTEC setup.
Any suggestion or answers would be great guys.
Old Sep 8, 2004 | 09:53 PM
jdm_cars's Avatar
Default Re: Intake Manifold Question? (Lamska)
OBD0 intake manifold?
The manifold is just metal pipes...
you mean the connectors for the sensors on it are OBD0 right? like the ICAV and IAT sensors....
If I am not mistaken, you need to reuse those sensors anyway when you swap the manifold, like to a skunk2 one, so I doubt it should be a problem for you, since you are only swapping the piping which doesn't care what obd system you are running.
Old Sep 8, 2004 | 09:54 PM
jdm_cars's Avatar
Default Re: Intake Manifold Question? (jdm_cars)
BTW, can't you just adjust the throttle cable to make it idle lower?
Old Sep 8, 2004 | 11:11 PM
Rad_Teg's Avatar
Don.t use the cable to adjust idle, use the idle air screw on the throttle body. That's the correct way to do it.
uvamosk
15
Mar 7, 2012 02:26 PM
tdizz07
Mar 28, 2007 06:58 PM
si0385.
Jan 9, 2006 06:47 PM
project_X
Feb 15, 2003 09:19 AM
