00' GSR ECU (P72) in 98 civic?
aight guys in buying parts for my lsvtec i aquired a 00' gsr ecu i was just curious what would happen if i hooked it up to my car stock with the SOHC VTEC still in place (would this even be possible?)
just curious *shrug*
Modified by dornon13 at 5:42 AM 9/9/2004
It won't fit in the first place...OBD2a and b ECU connectors don't mix very well.
96-98 Civic = 98-99 Teg: OBD2a
99-00 Civic = 00 Teg: OBD2b (perhaps 01 too, but I only have the 98-00 Teg Helms ETM)
...like EE_Chris said, you won't be able to use the 00 GSR ecu in your car, unless, you get an OBD2a->OBD2b ecu jumper harness (which I sell).
Hit me up if you're interested in purchasing on (check my ecu site link in my sig).
also, you'll have to get the IMMobilizer removed from the 00 GSR ecu if you really want to use it in your car, otherwise your car will not start.
