Which ecu and harness needed???
Old Sep 8, 2004 | 07:57 PM
jensintegra's Avatar
Default Which ecu and harness needed???
I did the ls/vtec head swap on my 90 integra and I need to know what ecu and wiring harness is needed. I have a b18a bottom end with a JDM b16a head. Where can I get these parts also.
Old Sep 8, 2004 | 08:25 PM
b18cls1's Avatar
Default Re: Which ecu and harness needed??? (jensintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jensintegra &raquo;</TD></TR><TR><TD CLASS="quote">I did the ls/vtec head swap on my 90 integra and I need to know what ecu and wiring harness is needed. I have a b18a bottom end with a JDM b16a head. Where can I get these parts also. </TD></TR></TABLE>
you either need a 0bd0 pr3 or pwo or get a obd0---&gt;1 conversion harness and get a obd1 ecu i have some obd1 ecu if needed and can get the harness for it.
Old Sep 9, 2004 | 07:34 PM
Default Re: Which ecu and harness needed??? (b18cls1)
HOW MUCH DO YOU WANT FOR THE ECU AND HARNESS????? Thanks for the info!
Old Sep 9, 2004 | 10:17 PM
rev-speed's Avatar
keep ur stock harness!!!
and stock ecu
just chip it and run turboedit
and add a shift light, msd window switch,vafc or ect. to turn on vtec.
u will save alot of money
Old Sep 10, 2004 | 07:07 AM
mmuller's Avatar
Mad Scientist
Default Re: (4cylinder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4cylinder &raquo;</TD></TR><TR><TD CLASS="quote">keep ur stock harness!!!
and stock ecu
u will save alot of money</TD></TR></TABLE>
no, thats not the right way....and you wont save money.
non vtec ecu will not run vtec...doh and if you use vafc for vtec fuel maps timing will still be off.
you can use your stock harness though, just add vtec wires and knock(if applies)
i would say convert to obd1, get a p28 wich are cheap and chip it for dohc
Old Sep 10, 2004 | 10:17 PM
rev-speed's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
i would say convert to obd1, get a p28 wich are cheap and chip it for dohc</TD></TR></TABLE>
really a vafc won t do the job?
is that why theres so many guys running afc hatck?
is that why dnr made over 225 hp running stock 240cc injectors and a vafc plus chip ecu with skunk program with a gsr motor on stock bore!!!
yea go ahead and pay $150 4 a p28
then a jumper harness $120
and a dist $250
or u can do what my buddys do
run a chip pm6 with a turboedit program
chipping pm6 $50
a msd rpm window switch $80
by the way i got tune programs 4 ls-vtec with stock ls pistons all motor and nitrous
(4 nitrous i have 80 shot direct and all single nozzle programs)
Old Sep 10, 2004 | 10:28 PM
mmuller's Avatar
Mad Scientist
please stop blabbing..
what does afc hack have to do with anything?
what your buddies do might work for boosted cars.
you say skunk 2 prog., well that's for a vtec ecu.
timing will be still off....vafc wont compensate for ig. timing that the mid lobe needs.you need a vtec ecu for that; or have one transformed to one.
? what? for whatever your trying to say; do you want a cookie?
Old Sep 10, 2004 | 10:32 PM
rev-speed's Avatar
if u run a chip program from turboedit
u can advance timing just like skunk program, mugen ericks racing and others
and turboedit is not only made 4 turbo
its called turbo edit u can run allmotor with it
if u quit being an *** u will learn something!!!
Old Sep 10, 2004 | 10:43 PM
mmuller's Avatar
Mad Scientist
dude, i know what turbo edit is..
yes you can control timing but its still not the the same as running a vtec ecu; 1 fuel map vs. 2 fuel maps; 1timing map vs.2.
Old Sep 10, 2004 | 10:57 PM
rev-speed's Avatar
thats why u run a vafc
Old Sep 11, 2004 | 07:40 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4cylinder &raquo;</TD></TR><TR><TD CLASS="quote">thats why u run a vafc
omg, i give up on you
Old Sep 11, 2004 | 12:06 PM
b18cls1's Avatar
omg, i give up on you</TD></TR></TABLE>
wow surprised it tokk that long i was done long before that
and by the way mmuller you are right
legend99
11
Apr 3, 2012 04:47 AM
gsrturbo-ek
Northeast (Sales)
Oct 17, 2011 05:29 AM
tuan...
Jan 4, 2004 08:07 PM
