oil leaks on my 92 accord
Old Sep 8, 2004 | 04:33 PM
drkshdw107's Avatar
Default OIL LEAKS ON MY 92 ACCORD
ok...i have a 92 accord DX that leaks oil and i cant find the leaks...leak #1 from under the car looks like its coming from the oil sending unit...i replaced it as well as the valve cover gasket, oil filter and oil pan gasket...didn't know if anyone might have any ideas about that one.
leak #2 is leaking into the spark plug tubes which in turn is destroying my wires...everytime i pull a wire its got like an inch and a half of oil on it....i have replaced the grommets on there 3 different times and i am loosing my mind trying to figure this out...i can't find any TSB's anywhere...so if anyone can help that would be great. thanks
Modified by drkshdw107 at 7:31 PM 9/8/2004
Old Sep 9, 2004 | 07:00 AM
JimBlake's Avatar
Default Re: OIL LEAKS ON MY 92 ACCORD (drkshdw107)
#2: Some engines (don't know about '92??) have another seal in the spark plug tube. The camshaft bearing caps form the top of the tubes, & there's an o-ring where they mate with the head. It's an inch or so below the grommets you replaced on the valve cover.
Old Sep 9, 2004 | 11:15 AM
iongerz's Avatar
crank shaft seal might be the problem.. i had the same problem....
i changed the main seal...
While your there you could change the timing belt and water pump...
Old Sep 9, 2004 | 01:57 PM
drkshdw107's Avatar
Default Re: OIL LEAKS ON MY 92 ACCORD (JimBlake)
cool...ill check that out...thanks
Old Sep 9, 2004 | 02:32 PM
91EXRMANUAL
Guest
Posts: n/a
Did u check the oil sensor? they have leaks alot.. i had it once.
Old Sep 9, 2004 | 02:41 PM
TxTuner
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">#2: Some engines (don't know about '92??) have another seal in the spark plug tube. The camshaft bearing caps form the top of the tubes, & there's an o-ring where they mate with the head. It's an inch or so below the grommets you replaced on the valve cover.</TD></TR></TABLE>
Like he said. This seal is used to keep oil out of the plugs.
Rocinante
May 24, 2015 07:49 PM
94delsiblk
Nov 1, 2010 06:20 PM
mapmaker8
Aug 3, 2010 08:53 AM
Mualphapiper
Jun 8, 2006 05:06 PM
