If My D4 Light Is Blinking...
Old Sep 8, 2004 | 03:42 PM
J-Ra's Avatar
Default If My D4 Light Is Blinking...
On my 94 Accord EX, does that mean my transmission is gonna blow??? I really dont think so i think something is just messed up with the light but this cat I work with said that my tranny is going so I wanna know what up with that. If anyone knows get at me. thanks and much appreciated.
And oh yea, I put on a windshield decal and it gave me 74% increased horsepower
lets see who takes that serious lol
Old Sep 8, 2004 | 06:14 PM
TxTuner
Guest
Posts: n/a
Default Re: If My D4 Light Is Blinking... (J-Ra)
The D4 light blinks simply to let you know the tranny needs to be checked (like a CEL). This might or might not mean your trannies gonna blow, but take it easy till you can have it looked at.
Old Sep 10, 2004 | 10:16 AM
criptic's Avatar
yea its either that your tranny is bad or u need to change your speed sensor i had the same prob and it turned out to b the speed sensor
Old Sep 10, 2004 | 10:25 AM
Its_real&its_spectacular's Avatar
New User
Default Re: If My D4 Light Is Blinking... (criptic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by criptic &raquo;</TD></TR><TR><TD CLASS="quote">yea its either that your tranny is bad or u need to change your speed sensor</TD></TR></TABLE>
Actually there are dozens of codes for the transmission, some with simple fixes, some not. It could be almost anything. Keep us posted ok?
Old Sep 10, 2004 | 12:29 PM
TxTuner
Guest
Posts: n/a
Default Re: If My D4 Light Is Blinking... (Its_real&its_spectacular)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Its_real&its_spectacular &raquo;</TD></TR><TR><TD CLASS="quote">Actually there are dozens of codes for the transmission, some with simple fixes, some not. It could be almost anything. Keep us posted ok?</TD></TR></TABLE>
Again, nothing that wasn't said before. Want to be helpful, post your list of the dozens of tranny codes . Hell, I'd like to see those.
Old Sep 11, 2004 | 04:15 PM
criptic's Avatar
1986-1990 Accord (G1)
Code # Explanation
1 Front Oxygen Sensor
2 Rear Oxygen Sensor
3 Manifold Absolute Pressure Sensor
5 Manifold Absolute Pressure Sensor
4 Crank Angle Sensor
6 Coolant Temperature Sensor
7 Throttle Angle Sensor
8 Top-Dead-Center Position Sensor
9 Number 1 Cylinder Piston Position
10 Intake Temperature Sensor
12 E.G.R. System
13 Atmospheric Pressure Sensor
14 Electronic Idle Control Module
15 Ignition Output Signal
17 Vehicle Speed Sensor
18 Ignition Timing Adjustment
1991-1995 Accord (G2)
Code # Explanation
1 Left Oxygen Sensor
2 Right Oxygen Sensor
9 Number 1 Cylinder Position (No. 1 Sensor)
12 E.G.R. Sensor
16 Fuel Injector
23 Left Knock Sensor
41 Left Oxygen Sensor Heater
42 Right Oxygen Sensor Heater
43 Left Fuel Supply System
44 Right Fuel Supply System
45 Left Fuel Metering
46 Right Fuel Metering
53 Right Knock Sensor
54 Crank Angle 2 Sensor
59 Number 1 Cylinder Position (No. 2 Sensor)
hope this helps this is all the info i dug up in the trannys
Old Sep 12, 2004 | 04:42 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-Ra &raquo;</TD></TR><TR><TD CLASS="quote">On my 94 Accord EX, does that mean my transmission is gonna blow??? I really dont think so i think something is just messed up with the light but this cat I work with said that my tranny is going so I wanna know what up with that. If anyone knows get at me. thanks and much appreciated.
What trouble code does it have stored?
Old Sep 12, 2004 | 04:44 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by criptic &raquo;</TD></TR><TR><TD CLASS="quote">1986-1990 Accord (G1)
Code # Explanation
12 E.G.R. System
Code # Explanation
12 E.G.R. Sensor
16 Fuel Injector
hope this helps this is all the info i dug up in the trannys</TD></TR></TABLE>
Those aren't tranny codes.
Old Sep 12, 2004 | 06:25 AM
J-Ra's Avatar
Default Re: If My D4 Light Is Blinking... (Chiovnidca)
To be honest I dont even know how to read the codes it gives out or anything. I dont know how to find out what codes its giving out or where to look. When it comes to car problems like that I'm straight foreign wit that. sorry but Ill try to look into it or somethin. thanks for the help everybody though I do appreciate it
Old Sep 12, 2004 | 09:49 AM
jwogen1's Avatar
it could be your solenoids, that was my problem
slosmogman
Apr 29, 2006 07:54 AM
Civic4less
Jan 12, 2006 06:16 PM
mike93eh
Sep 29, 2005 02:01 PM
wtaylor70
Aug 11, 2005 12:49 PM
Blue10karat
Jul 9, 2003 09:27 PM
