Finding TDC
Old Sep 8, 2004 | 02:30 PM
gsrjay's Avatar
Default Finding TDC
Putting my head back on block and trying to find true TDC.Marks wont line up because head has been milled.My question is do you ignore the cam gear marks and use the locking pin holes in the cams as a referance to find TDC ie with the crank lined up with the mark on the lower cover.Or should you use the gear marks as a referance?Right now with the lower mark lined up the intake cam is at zero and the exaust cam is 4 degrees and the pins locked are straight up. Thanks
Old Sep 9, 2004 | 04:51 AM
gsrjay's Avatar
Default Re: Finding TDC (gsrjay)
Anyone please
Old Sep 9, 2004 | 08:28 AM
chad174's Avatar
Set both your cam gearsto zero, make sure of it. I had kinda the same problem with my ls head that was milled .030. But I was wrong or something, because now it lines up great. It should for you too. The tip is not to try to line the marks up with the head, but to make sure the marks are pointing at each other on the inside side of the cam gears. Hope that helps.
Old Sep 9, 2004 | 09:10 AM
FeatherWeight
Guest
Posts: n/a
Try the exh cam trick.
Old Sep 9, 2004 | 09:38 AM
spaceman's Avatar
Default Re: Finding TDC (FeatherWeight)
exh. cam trick?
84Riceeater
13
Jun 27, 2014 09:30 AM
thekooler
27
Mar 23, 2012 05:25 AM
OH_1fstgsr
Jan 24, 2010 06:10 PM
Brewer
Jan 13, 2004 10:58 AM
