need help on my B18A1 swap
ok so i have a 91 civic hatch and just bought a peice of **** 92 teg LS i want to do the swap looking for best parts to use and any advise i can get before i get lost in a honda swap hell.
u have an excellent beginners swap there.
all you need are the mount kit and shift linkage.
drain all the fluids (coolant,trans and oil)
pull all the hoses off the motor that go to the firewall and to the radiator (vaccum and coolant, and pull the radiator)
pull the shiftlinkage and axles out (pitchpin, axlenuts and lowerballjoint are the main highlights there
take the wiring off the motor and throw it to the side
pull the clutch cable. then pull the engine
i think i got it all
oh yeah that teg radiator will boltin the civic and is a terrific upgrade. i would also look at taking the brakes, axles, and master cylinder with brake booster off that teg.
)take the wiring off the motor and throw it to the side
u can put it in before. but i would pull it out when i pull the engine to prevent damaging it
if the teg is an auto theres a couple of extra hoses running to it, just take them off and everything will fit in fine
and welcome to honda tech
i know i'm doing the teg brakes in the front but i dont know about the rear and how to do all of that unless you just switch the parts and reconnect. same with the suspension i'm for shure taking the shocks and springs in the front for all of the added weight. next, i do have the STD model and what the hell is mpfi i have the entire car to hack apart so is it already there?, gimme some info PLEASE i'm trying to learn as much as i can before i try this madness. oh yea would it be easier to convert the motor to obd0 or the car to obd1, what's the difference?
thanks for the onfo looking foreward to more
.Noah Fecks
Aug 23, 2003 12:54 AM
