1992 Civic Si w/ F20B swap, Utah
Old Sep 8, 2004 | 01:08 PM
my_slow_civic's Avatar
Default 1992 Civic Si w/ F20B swap, Utah
The car is located in Utah. It has a clean title, VIN upon request. I open to trades, but am looking to get a EK hatch.
Here is a list of everything on the car:
1992 Civic Si
186,XXX miles on chassis
7,500 miles put on motor while in the car.
98' JDM F20B From the Accord SIR-t It is a quicker, higher revving motor than
the h22a. (200 HP, 160 TQ)
H23 non LSD tranny.
Hotshot 4-1 Drag header (purchased used from someone off of honda tech)
2 1/4" crush bent piping, with test pipe.
Dragunfire muffler
Tokico Blues shocks
Arospeed 800lb coilovers
Skunk 2 upper STB
"Vision" Amber Corners
Projector headlights
OEM foglights
Piaa Bulbs
GSR leather seats (front only)
JUN chipped P28 ECU
Viper Alarm
Remote Keyless entry
VIS Carbon fiber hood.
ACT Stage 3,6 puck sprung clutch
Clutch Specialties Lightened flywheel (12lbs)
Center Consol Armrest
Pioneer CD player
4 Alpine speakers
Aluminum radiator
Slimline fan
Duckbill wing
Brand X intake
Skunk2 Stage 2 cams Have box and reciepts
Skunk2 dual valve springs and retainers
93' Integra wheels
AEM fuel rail
AEM FPR
B&M fuel pressure gauge
The F20 motor was dropped in right about
179,XXX miles. At roughly 183,XXX miles, I pulled the motor to install the
cams. At this time I replaced pretty much everything else. All parts are OEM
Honda parts, and I have reciepts for those as well.
Intake and exhaust manifold gaskets
Valve cover, and spark plug port gaskets
Head gasket
Water pump
Oil pump
Front and rear main seals
Balance shaft seal
New timing belt tensioner
Timing Belt
Balance shaft belt
Oil pan gasket
Cam seals
throttle body gasket
OEM oil filter and Fuel filter
Valve Seals
I used OEM coolant, and I use fully synthetic Castrol oil.
At this time I put in the new ACT clutch, and had the flywheel resurfaced.
The axles were replaced with new axles as well.
Front brakes and rotors were replaced
All valves were reseated upon installation.
Stock cams and valve springs can be included.
I usually get anywhere from 260-300 miles to a tank. The alarm works fine, and locks the doors automatically upon starting the car. Both keypads work. Cruise control is also functional as well. There is no AC or power steering. Both dont bother me. I am sure they could be put back in if one wanted to. The car also has a clean title. The exhaust, with the silencer out, is somewhat loud, but sounds good. With the silencer in, you cannot tell there is an exhaust on the car, unless under full throttle, it buzzes.
The bad- Overall, I feel this car is mechanically in awsome shape, and I would
drive it anywhere. Bodywise, it is showing its age. Since the car came from
california, I am going to blame the faded clearcoat on the sun. The only part
that has sun fade, is on the roof of the car, and can be seen in the pictures.
I am not sure how the front and rear bumpers were beat up. My guess is by
careless parking. But the flaws can also be seen in the pictures. The driver side seat is starting to show some wear on the typical spot. The windshield is cracked, due to a nice rock thrown from a car on the freeway. There is not windshield trim, as I bought the car that way. The glass companies I have called said they can replace that, along with a new window.
Asking price $6100 OBO
Email with questions.
More pictures available.
Modified by my_slow_civic at 4:35 PM 10/2/2004
Old Sep 8, 2004 | 02:08 PM
egSpoonR's Avatar
Default Re: 1992 Civic Si w/ F20B swap, Utah (my_slow_civic)
bUMp for an uncommonly used motor...sick bro, very original ...
Old Sep 8, 2004 | 06:20 PM
Default Re: 1992 Civic Si w/ F20B swap, Utah (egSpoonR)
bump
Old Sep 10, 2004 | 08:09 AM
bump
Old Sep 10, 2004 | 09:38 AM
Brewer's Avatar
F20B
Old Sep 10, 2004 | 06:17 PM
Default Re: 1992 Civic Si w/ F20B swap, Utah (BrewerHatch)
Does my car suck that bad?
Old Sep 14, 2004 | 12:39 AM
99CivicExCoupe's Avatar
its all about the F20B, great motor in my opinion....good luck on sale...honestly i recommend touchin it up, fresh paint, a little body work, paint valve color blue, and get new windshield...altogethe you can get it done for abt $1000, and i think it will add a lot of value to ur car, but 7100....regardless of how good the motor and shocks are...is a lot becuz of the condtion...nonetheless good luck bro, sick engine
Old Sep 14, 2004 | 01:47 AM
EGJdmJreams's Avatar
i agree car could be worth that with a fact o bake paint job
Old Sep 16, 2004 | 06:00 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (EGJdmJreams)
Nice car.
The F20b actually has 145 not 160 tq from the factory. Not that it matters, since you have the S2S2 cams.
Old Sep 18, 2004 | 09:47 AM
sanjiyan69's Avatar
Default Re: (rochesterricer)
would you ship the car?
Old Sep 25, 2004 | 10:26 AM
Default Re: (sanjiyan69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanjiyan69 &raquo;</TD></TR><TR><TD CLASS="quote">would you ship the car?</TD></TR></TABLE>
Yes.
Also, windshield and window mouldings are scheduled to be replaced this week. Price is OBO.
Also, I have a set of Si wheels and tires with 95% tread left I could throw on to sweeten a deal.
Modified by my_slow_civic at 1:03 PM 9/25/2004
Old Sep 27, 2004 | 10:18 AM
bump
Old Sep 27, 2004 | 02:08 PM
TrYtoEz's Avatar
Default Re: (my_slow_civic)
bump
Old Sep 27, 2004 | 02:40 PM
ian.'s Avatar
Default Re: (TrYtoEz)
sick
Old Sep 28, 2004 | 09:23 AM
Default Re: (IC33)
Bump
Old Sep 28, 2004 | 10:25 PM
TrYtoEz's Avatar
did u get a chance to replace the windshield? how bout the hatch cover...lmk...bump
Old Sep 29, 2004 | 09:38 AM
Windshield is being replaced later today, and the hatchcover has not been replaced. I havent been able to find one.
Old Sep 29, 2004 | 03:35 PM
bump
Old Sep 30, 2004 | 10:01 AM
bump..
Old Sep 30, 2004 | 10:26 AM
Chicano's Avatar
bump for a unique si
Old Sep 30, 2004 | 02:30 PM
Default Re: 1992 Civic Si w/ F20B swap, Utah (skaterguy)
thanks for the bump.
Old Oct 1, 2004 | 12:28 PM
bump again. damn
Old Oct 2, 2004 | 02:29 PM
down
Old Oct 4, 2004 | 12:58 AM
for a gangsya motor, i love it
Old Oct 4, 2004 | 09:31 AM
Default Re: 1992 Civic Si w/ F20B swap, Utah (99CivicExCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99CivicExCoupe &raquo;</TD></TR><TR><TD CLASS="quote">for a gangsya motor, i love it</TD></TR></TABLE>
Thanks for the bump
