SIR front ? and other Qs
Pirate General...YARRRR
well i kinda hit some gravel and it tore my poor old STDs bumper. its been banged up lil bit but now its to a point i'd like to fix it some how.
I'm thinking either SIR front will this fit up with my Vis C/F ZC hood?
Is there a way to make exhuast come out of the right side of the car for rear bumper thats cheap?
anyone know if you can still get the OEM std bumpers cause i either want the SIR or my STD OG look.
nother question where is that list of b16 swap parts you use like what axles etc etc? why isn't it a sticky mods can you make it one? I think it would help lotta people.
last thing i looked but wheres that link for the custom A/C mount for b motors i would LOVE to find it
TIA
TIA
1.)you can use your ZC hood if you only get the SiR bumper...but if you are talking the whole conversion then you need to use the SiR hood because of headlight fitment etc.
2.) any muffler shop can do that for you, but i don't think there is a aftermarket kit persay unless you are talking straight JDM but that is not cheap
3.) people are parting out std's all the time..go to a junkyard, look on this board, ebay, etc. iw ouldn't pay anymore than like $30 for a good one.
4.) parts I used if you are staying witht obd0, pr3 ecu, 90-93 teg axles, mount kit, shift linkage (you can weld modify a stock one or get place racing or hasport), b series cable tranny, and of course a b16 would help.
5.) Hasport I thought made the AC bracket?
thanks man so i can get bumper and headlights fenders and run ZC hood?
i worded my exhaust question poorly I would like to have it come out the other side looking stock with cut out moved to other side.
ok cool i may snag some STD bumpers for now cheap then I'm picky its not bad at all lol.
yet again shitty wording on my part i meant things like clutchs are the 99 SI axles 93 teg that kinda stuff. But having both lists sticked would be an awesome idea.
hasport does but they want like 200 and i'm a DIY kinda guy too i member seeing it here and i'd love to do it.
thanks again for help man
no you can only use the bumper and the zc hood together...
if you use the SiR bumper, lights, and fenders then you must use the SiR hood.
as far as the that rear bumper...you will just have to have a shop cut out the other side then fill in with fiberglass your stock area. Or try to score a JDM rear bumper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper »</TD></TR><TR><TD CLASS="quote">
nother question where is that list of b16 swap parts you use like what axles etc etc? why isn't it a sticky mods can you make it one? I think it would help lotta people.</TD></TR></TABLE>
That's what the search function is for.
the ZC hood is NO different than the US hood aside from the bump. the SiR hood IS different, you would need the SiR bumper AND SiR Headlights AND SiR Rad Support unless you run it on hood pins and no latch. heres mine before after.
Modified by Ch3mik at 4:10 PM 9/8/2004
ok cool thanks again for all the help! So just to double check I could do SIR bumper US lights and ZC hood?
El vap I know theres a search key I use it alot. I was just thinking it would be a really nice sticky to have those lists up being I can't be the only one who wants to see it alot and i know its asked every 45 seconds it was mearly a sugestion to try help no harm meant.
For the bumper... friend has a 89 CRX SI, used dremel to cut notch out of right side. Can't tell from a distance; i never noticed it wasn't stock till he pointed it out to me. Having the notch on both sides looks kinda cool too.
yea but the US crx bumper lights dont wraparound, the bumper is very boxy as opposed to the more curvy EF8 bumper and the EF8 metal bumper support is a very thin metal bracket as opposed to the US huge metal black support. plus the hood front would hang past the middle top of the bumper because a JDM hood is appx 1" longer. A true crxpert would spot it.
hmotorsonline.com...steves a great guy. got mine for $850.00 shipped with EVERYTHING...complete nose cut. mine had the clear coat peeling and a good amount of scratches but no dents or anything significant. looks great and is less wait...dont cheap out and just get the bumper...get the whole thing...it looks MUCH better and its JdM Yo
5zigen makes an axel back that you can get that comes out under the pass side rear bumper, sounds pretty nice i've heard before, but only an axle back
hasport a/c bracket, pay up
SuperCivic
20
Aug 24, 2002 08:46 PM
here is how i did my exhaust the bumper looks ok this way fillininthe other side could take time plus you would have to get it painted
