Sleeving B18C5
Old Sep 8, 2004 | 12:35 PM
Bradstard's Avatar
Default Sleeving B18C5
I asked this same thing in the All Motor forum. I thought I'd post here to see if you guys give the same answers...
I am going to sleeve my B18C5 to 85mm. I was planning on having it sleeved with the AEBS 85mm closed deck. I can also go with a Benson 85mm open deck for about the same price. I just found out that it is going to be about two weeks before they get more AEBS sleeves in stock. 2-3 week turn around from that point. I am looking at about the same time frame for the Benson sleeving. This is going to be a 12.5:1 N/A setup. Being that price and turn around is about the same, which one should I go with?
Old Sep 8, 2004 | 12:40 PM
ZygSpeed's Avatar
Default Re: Sleeving B18C5 (Fat Bradstard)
I've heard nothing but good things about Benson.
esponet's Avatar
i went with darton sleeve. through ldl speedshop in vegas.
but between the two choice you gave i would probably go with benson, only cause so you said aebs is out of stock and who knows maybe they will be delayed on getting the new ones. or maybe they won't get enough and some guys might get bumped.
unless your preparedto wait, iwouldnot gowith a company that don't have them readilly available now. nothing wrong with aebs if they had it instock i would have probably choose them
Old Sep 8, 2004 | 01:21 PM
1Quikgsr's Avatar
Default Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">i went with darton sleeve. through ldl speedshop in vegas.
unless your preparedto wait, iwouldnot gowith a company that don't have them readilly available now. nothing wrong with aebs if they had it instock i would have probably choose them</TD></TR></TABLE>
LDL is awsome go see dennis he will hook you up good guy.
Old Sep 8, 2004 | 01:29 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: (1Quikgsr)
Darton sleeves are nice, but the Benson would be my choice, just for turn around time.
Old Sep 9, 2004 | 07:53 AM
gaskleppie's Avatar
Where can I buy Benson sleeves?
Old Sep 9, 2004 | 07:58 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr &raquo;</TD></TR><TR><TD CLASS="quote"> LDL is awsome go see dennis he will hook you up good guy. </TD></TR></TABLE>
I doubt he's going to travel more than 1/2 way across the country to have his block sleeved.
Old Sep 9, 2004 | 08:04 AM
FeatherWeight
Guest
Posts: n/a
Default Re: (gaskleppie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaskleppie &raquo;</TD></TR><TR><TD CLASS="quote">Where can I buy Benson sleeves?
Contact "Earl" on this board, thats his username btw.
Old Sep 9, 2004 | 08:52 AM
Johnny Tran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard &raquo;</TD></TR><TR><TD CLASS="quote"> which one should I go with?</TD></TR></TABLE>
none....unless your boosting.
Old Sep 9, 2004 | 09:37 AM
len's Avatar
len
Default Re: Sleeving B18C5 (Johnny Tran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Tran &raquo;</TD></TR><TR><TD CLASS="quote">none....unless your boosting.</TD></TR></TABLE>
And naturally I semi-disagree.
On an all-motor setup, sleeves isn't a necessity for the amount of power created, but if you wanted to increase displacement the stock sleeves are only good to about 82mm. After that, they are too weak. In that case you have several options, purchasing a B20 block, for instance, or getting the current block resleeved. If I was strictly on a budget, perhaps a B20 block would be the better alternative, but if I had the money, I would most definitely sleeve. It all really just depends on what setup your trying to build at a given budget.
Old Sep 9, 2004 | 10:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">... my B18C5 to 85mm. </TD></TR></TABLE>
i guess i could have read the post thoroughly....lmfao
Old Sep 9, 2004 | 10:42 AM
RTW DC2R's Avatar
I was gonna go with Benson on my set up (though Earl on HT). Quick turn around time, sleeved to whatever size you want, with Pauter rods, and CP forged pistons, micropolished and fully balanced assembly...If you havent talked to Earl yet, I would recommend you do so. Search for his posts as well, others have used his/their services and I dont think I read a single complaint about ANYTHING, service or quality seems top notch.
Old Sep 9, 2004 | 12:34 PM
len's Avatar
len
Default Re: (RTW DC2)
Earl and Benson is the only way to go. It's just something about Earl being on here and helping contribute to the community and offer great services and back it up with support and feedback. Sorry, you can't beat that.
Another for Benson. I've seen their products and almost finished a Benson Sleeved 2.0 CRV Turbo setup if the owner didn't run out of money and ditch it. LoL Top Notch stuff.
Old Sep 11, 2004 | 05:49 AM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: (len)
i've seen Benson's sleeves crack before. I'd stick with the Darton's.....
Old Sep 11, 2004 | 02:50 PM
Dan GSR's Avatar
buy your pistons
send them and the block to benson
excellent work from what ive seen
&lt;---also like endye rollerwaves for pistons
Old Sep 11, 2004 | 03:53 PM
ITRTurbo's Avatar
Default Re: Sleeving B18C5 (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">buy your pistons
&lt;---also like endye rollerwaves for pistons</TD></TR></TABLE>
This reminds me. How are things comming along with my block?
Old Sep 11, 2004 | 04:40 PM
b19coupe's Avatar
Dan Benson.
Both my engines were sleeved by him.
Top notch machine work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nvious R &raquo;</TD></TR><TR><TD CLASS="quote">i've seen Benson's sleeves crack before. I'd stick with the Darton's.....</TD></TR></TABLE>
I am having a hard time buying that one. Proof???
Old Sep 11, 2004 | 08:15 PM
RTW DC2R's Avatar
Default Re: (Nvious R)
If Im not mistaken, he uses Darton sleeves so this wouldnt make much sense.
Old Sep 14, 2004 | 09:53 AM
go250mph's Avatar
Dart makes a replacement block now that comes with a closed deck.It would probably end up cheaper in the long run,and a lot more durable!!!
Old Sep 14, 2004 | 10:02 AM
RTW DC2R's Avatar
whats so great about a closed deck? Im pretty sure Benson doesnt do closed decks but I dont remember the reasoning behind it.
Old Sep 14, 2004 | 10:06 AM
Bradstard's Avatar
Default Re: (go250mph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by go250mph &raquo;</TD></TR><TR><TD CLASS="quote">Dart makes a replacement block now that comes with a closed deck.It would probably end up cheaper in the long run,and a lot more durable!!!</TD></TR></TABLE>
They are not cheaper.....but they are more reliable.
Old Sep 14, 2004 | 10:10 AM
Default Re: (Fat Bradstard)
They are not cheaper.....but they are more reliable.</TD></TR></TABLE>
hrmmm.....the two people I know with dart block based engines have had nothing but trouble with them, both built properly.
:shrugg:
Old Sep 14, 2004 | 10:51 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: (Johnny Tran)
Nice posting skillz, ya drunk
Didn't Dropspeed recently blow up a Dart "big block?"
Old Sep 14, 2004 | 10:59 AM
Default Re: (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote"> ya drunk </TD></TR></TABLE>
hey pot, its kettle....bitch
:fire:
Old Sep 14, 2004 | 11:01 AM
Bradstard's Avatar
Default Re: (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">Nice posting skillz, ya drunk
Didn't Dropspeed recently blow up a Dart "big block?"</TD></TR></TABLE>
I believe so. I'm sticking with OEM block just boring it out some.
