96 type-r wheels on the forth gen
hey the 96 integra type-rs came in 4x114.3 and i was just wondering if any one here has ever put them on their forth gen. and also if they have any pictures. thanks
That black lude is with USDM 5 Lug ITR rims. nice but he was lookin for this red one = https://honda-tech.com/zerothread?id=683880
I recently purchased the Type R wheels you are talking about, I only have 3 right now but I got them for a good price so I didn't want to pass up the offer. I did however mount 2 of the wheels on the front but I had to use some spacers in order to clear the brake calipers. The wheels are also very light about as light as rota wheels if not a bit lighter. Here's a pic I have, not too good but you get the idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daboi630 »</TD></TR><TR><TD CLASS="quote">same size yes. but the offset of the rims are different by 5mm</TD></TR></TABLE>
Yup, I was suprised when I first found out about the problem. I'm using 3mm spacers, other then that though, the wheels are great, I recommend them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andlude »</TD></TR><TR><TD CLASS="quote">so will 205/55r15s fit on these rims? and did you just use the spacers from pepboys or something?</TD></TR></TABLE>
205/55/R15 Should fit fine on the wheels, I'm currently running 205/50/R15 Falkens on the Type R wheels. I believe the wheel is a 15X6. The spacers I got from a local tire shop around my house, I'm sure any wheel/tire shop should stock them.
I now have I/H/E/VAFC(untuned), back when I hit that 14.1 I only had I/E and I used slicks to hit the 14.1 but with the Azenis I recently got I hit the same 60' times I hit with the slicks, I even broke my record with the Azenis. Send me a PM if you have more Q's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andlude »</TD></TR><TR><TD CLASS="quote">i got the rims today, AND IM GONNA GET THE SPACERS AND MOUNTED TOMAROW!
Where did you get your wheels from? Don't forget to post pics of your ride with the wheels mounted, good luck
</TD></TR></TABLE>Where did you get your wheels from? Don't forget to post pics of your ride with the wheels mounted, good luck
suzieffbaby
Oct 19, 2012 08:27 PM
