Using SeaFoam!!!! help GSR!!
Old Sep 8, 2004 | 10:11 AM
Dc2 Powered's Avatar
Default Using SeaFoam!!!! help GSR!!
on a gsr where would u poor in the seafoam? just a quick answer please.
Old Sep 8, 2004 | 10:13 AM
PlastikOwl
Guest
Posts: n/a
Default Re: Using SeaFoam!!!! help GSR!! (Dc2 Powered)
use the brake booster line to suck it up.
Old Sep 8, 2004 | 10:32 AM
dFreezy's Avatar
seafoam guide
Old Sep 8, 2004 | 10:33 AM
sweet, thx
Old Sep 8, 2004 | 11:49 AM
devi1man's Avatar
Default Re: Using SeaFoam!!!! help GSR!! (bl@sterVT)
Seafoam is great! not just for two cycles.
The only thing different I remember from the Seafoam information video was to run a third of a can through the booster vacuum line, a third in the gas tank, and a third in the oil. I haven't seen the video in about 3 years so that may have changed.
You can also spray down the throttle body with Deep Creep which is the aerosol version of Seafoam.
Pesky damn 5 post limit
EDIT: Because of the limit...
You can idle your car with the T/B exposed but if you spray tb cleaner in, the car will stall. Just stick some old rags below the throttle body and spray it down while working the throttle manually with the engine off. Then reassemble and start.
Modified by devi1man at 1:12 PM 9/8/2004
Old Sep 8, 2004 | 12:00 PM
mistersparco's Avatar
washuuu
Default Re: Using SeaFoam!!!! help GSR!! (devi1man)
Isn't it dangerous to have the car running while exposing the T/B?
Old Sep 8, 2004 | 01:30 PM
dc2_tuner's Avatar
Default Re: Using SeaFoam!!!! help GSR!! (mistersparco)
Old Sep 8, 2004 | 01:33 PM
PlastikOwl
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mistersparco &raquo;</TD></TR><TR><TD CLASS="quote">Isn't it dangerous to have the car running while exposing the T/B?</TD></TR></TABLE>
only if you're trying to have sex with it.
Gsr.Turbo'd.Teg
May 7, 2007 03:59 PM
Spectrum24x
Jan 6, 2006 12:45 PM
out_of_order
Jun 17, 2005 11:50 AM
92siracer
May 10, 2004 06:19 PM
