90 accord wont turn on????????help
Old Sep 8, 2004 | 08:10 AM
blazinrola7880's Avatar
Default 90 accord wont turn on????????help
i need help with my friends 90 acord it wont turn on it cranks just dost turn on no spark or fuel i was thinking the ignition first den i saw the chek engine lite dosnt go on so i pulled da cpu out but it dosnt smell burnt i kno the chekengine lite soposed to go on and off could it be the brown relay???unmder da dash. please help anyinfo willl be apreciated. thanks.
Old Sep 8, 2004 | 03:21 PM
Default Re: 90 accord wont turn on????????help (blazinrola7880)
!!help.. he said he was driving shifted from 2 to 3 and it choked turned off the chek engine light went on den died .. help!!
Old Sep 9, 2004 | 06:55 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blazinrola7880 &raquo;</TD></TR><TR><TD CLASS="quote">... den i saw the chek engine lite dosnt go on ...</TD></TR></TABLE>Do you mean the CEL doesn't go on when you first turn on the ignition? That could be a bad ignition switch, or broken wiring to/from the switch.
Old Sep 9, 2004 | 05:42 PM
Default Re: 90 accord wont turn on????????help (JimBlake)
yea the cel ill chek the wiering but the car does crank just dosnt turn on and is dere an fusable link some were??? some one told me to chek grounds/.
Old Sep 10, 2004 | 03:45 AM
JimBlake's Avatar
Checking ground is good, check fuses too. The main relay could be it, too. A blown ecu fuse, or a bad main relay, or a bad ignition switch all do the same thing. As far as the ECU is concerned, it doesn't even know you've turned on the car.
Remember the ignition switch has 3 circuits; one for accessories, one for ignition, one for starter. Just because the starter works doesn't mean the ignition/EFI circuit is good.
You said you've had the ECU out?? Do you have a wiring drawing? I don't know which pins are supposed to be powered, but I'd check them with a voltmeter & go from there.
A fusible link is nothing more than a fuse built into a cable somewhere. Honda normally uses big (50 or 100 amp) main fuses in the fusebox instead of a fusible link. But that's just from my own cars, I don't know about '90...
Old Sep 10, 2004 | 06:40 AM
thanks on the info .im going to jump on it today hope fully i get her running so i can get payed.ill report bak later
Old Sep 10, 2004 | 09:35 AM
turned on but cel dosnt o well justr changed a fuse
maxrealtor
Mar 3, 2011 07:55 AM
jim lenfert
May 23, 2006 05:59 AM
redspiritguy
Dec 9, 2005 04:08 PM
JimKW
Sep 20, 2005 10:37 AM
notoriousB
Jan 11, 2005 03:28 PM
