jun 2 exhaust cam vs 98 spec itr exhaust cam
Old Dec 7, 2001 | 07:08 AM
gsr98vtec's Avatar
Default jun 2 exhaust cam vs 98 spec itr exhaust cam
mike k in his posts on the cams thinks these are very similar...does anyone have any numbers to back this up...i talked with a shop and they said the jun exhaust cam has a little more lift and that the lobes are bigger...is that really going to give me any more hp...
Old Dec 7, 2001 | 07:24 AM
Mike K's Avatar
Default Re: jun 2 exhaust cam vs 98 spec itr exhaust cam (gsr98vtec)
Well, the reason I did it because the DURATION isn't a whole lot greater than the stock ITR exhaust cam (or so I was told) ... that's why I didn't think it was worth the extra cash for the jun2 exhaust cam.
As you saw in the charts, just by adding the jun2 intake cam.. it made a huge difference over the 00 ITR intake cam...
i'd like to try the jun2 exhaust cam in the future just for the hell of it.
Old Dec 7, 2001 | 07:57 AM
naturalvx's Avatar
You've got one on the way. Let me know how it turns out.
Old Dec 7, 2001 | 08:49 AM
Xerzex's Avatar
New User
Default Re: jun 2 exhaust cam vs 98 spec itr exhaust cam (Mike K)
I was told the same thing. The performace the Jun II exhaust cam will bring does not outweigh the cost. I kinda liked the idea of only having to spend the cashish for one cam but now I'm going with the Jun IIIs.
Old Dec 7, 2001 | 08:59 AM
MPH's Avatar
MPH
New User
Default Re: jun 2 exhaust cam vs 98 spec itr exhaust cam (Xerzex)
Has anyone noticed that the Toda A intake cam is almost identical to the stock itr?
ITR profile
INTAKE lift - 11.5 mm,duration - 240 @1mm
EXHAUST lift - 10.5mm, duration - 235 @1mm
Toda A's
INTAKE lift - 11.6 mm,duration - 240 @1mm
EXHAUST lift - 11.2mm, duration - 240 @1mm
Old Dec 7, 2001 | 09:15 AM
Mike K's Avatar
Default Re: jun 2 exhaust cam vs 98 spec itr exhaust cam (MPH)
The ramp angle that the valves open I'm sure are different.
Also, the primary lobes on the A's are bigger... which is why they are stronger than ITR cams when off VTEC.
Old Dec 7, 2001 | 10:52 AM
MPH's Avatar
MPH
New User
Old Dec 8, 2001 | 11:28 AM
S&P500ITR's Avatar
New User
I believe your duration figure on the A's intake is wrong (250 instead of 240)
Toda A's
INTAKE lift - 11.6 mm, duration - 250 @ 1mm
EXHAUST lift - 11.2mm, duration - 240 @ 1mm
ITR:
INTAKE lift - 11.5 mm, duration - 240 @ 1mm
EXHAUST lift - 10.5 mm, duration - 235 @ 1mm
[Modified by S&P500ITR, 12:30 PM 12/8/2001]
iH8RICERZ
Northern California (Sales)
Oct 11, 2005 12:03 AM
bananacruzier
Feb 3, 2002 09:40 AM
itr501
Dec 10, 2001 06:10 PM
ic108
Nov 25, 2001 10:02 AM
