what turbo do you have and when do you reach full boost?
I'm wondering if I should keep my turbo or upgrade but wanted to keep it streetable with minimal lag. Please post your turbo, when you reach full boost, and how much boost you're running. Sorry if this is a repost but I'be serached and found nothing
Anyways, here's mine
TDO5H- 16G
2900rpm
12psi
TDO5H- 16G
2900rpm
12psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman »</TD></TR><TR><TD CLASS="quote">9.5 psi with garret t3/to4e i see full boost at around 4000rpm. </TD></TR></TABLE>
What Trim, that's what matters...
Garrett T3/T04E 60 trim with a .63 exhaust housing running 10psi by 4700rpms.
Turbonetics T3/T04E 57 trim 63 a/r (Drag3) @ 0.5bar tial spring.
Full boost at 4500.
Here's a dyno before I got a boost controller to even out the boost.
Full boost at 4500.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">16G 8 lbs at around 3500 rpms. on d16z6</TD></TR></TABLE>
same for me with a 15G at 6-7psi WTF!
maybe its the stock cat
B18C
10:1 Compression
boost starts around 3400, full boost @ 4700 rpms @ 10psi
t3/t4oe 57 trim .60/.63 ar's.
Hondata
281whp 181tq
2.5 inch DP and Exh.
Soon I'm gonn switch to a .48 turbine housing for faster spool.
10:1 Compression
Hondata
281whp 181tq
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">B18C
10:1 Compression
Hondata
281whp 181tq
Soon I'm gonn switch to a .48 turbine housing for faster spool.</TD></TR></TABLE>
I'm suprised that the 57 trim spools so late on a 1.8. I get around the same spool times with a 60 trim on the 1.6.
10:1 Compression
Hondata
281whp 181tq
t3/60-1 at 7psi hits full boost around 5500-6000RPM.
t3/60-1 at 10psi hits full boost around.......don't know yet.
The Full-Race manifold increases spool time by about 800 RPM so I won't be sure until I get the car on the road.
just installed a boost controller so it should be slightly better now.
before the controller:
2.2, full boost @ 4400-4600... t3/60-1 @ 8psi
edit: btw this is in 2nd gear.
Modified by twkdCD595 at 4:38 PM 9/11/2004
