h22a7 euro r swap in a prelude 4thgen ?
hi i was wondering if the h22a7 euro r accord is a straight drop in the 4th gen lude and what kind of modifcation needs to make it fit and also how about the ecu what ecu would i need to make it work i mean isnt it obd 2 or can i convert the harness from obd1 to obd2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries »</TD></TR><TR><TD CLASS="quote">Does anyone have dynos of the Euro-R ecu vs. an OBD1 P13?</TD></TR></TABLE>
euro-r ecu has electronic power steering..so I doubt it unles someone did it over in Japan...
H22A7 is the Type-R btw..but it has EPS as well
just curious but what do you mean
so this mean it will not work also is there any ways to make a copy of the ecu fuel mappings and timing mapping
The idea that since your not using the Electric Power steering unit in your lude, it will throw a CEL. Thus making you run in limp mode = dumping fuel and making your perfectly new swapped motor run like trash. If i were you i would go hondata, run one of thier reccomended chips, and when your ready you get your **** tuned by a good tuner and make it run real nice.
My friends have swapped the H22A7 into both a 90-93 Accord and a 93 Prelude... using the Accord-R ecu. There were no issues with the EPS throwing a CEL. The only problems were with the 3 wire IAC which was eventually wired up correctly.
HEY!!!!!!!!!!!!! IMPORTANT QUESTION!!!!!!!!! how did you wire up that 3 wire IACV sensor!!!!!!!! i'm doing an h22a7 swap into a DC2 integra.. and i just left the black wire out cuz i figured it was just a ground.. and if it didn't work, then i would just ground it.. but yah.. plz tell me what you did for wiring on it. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeejermons »</TD></TR><TR><TD CLASS="quote">HEY!!!!!!!!!!!!! IMPORTANT QUESTION!!!!!!!!! how did you wire up that 3 wire IACV sensor!!!!!!!! i'm doing an h22a7 swap into a DC2 integra.. and i just left the black wire out cuz i figured it was just a ground.. and if it didn't work, then i would just ground it.. but yah.. plz tell me what you did for wiring on it. Thanks.
Are you using the euro R wire harness? i used the stock LS wire harness and bolted up a civic ex IAC. The iac is kinda zip tied to the heater lines and i made block off plates for both the iac and the intake manifold and ran silicone lines to each. pm me if you need more help.. although i don't remember much about the swap. i dynoed 195/149 with a horrible tune and gsr timing map. i recently acquired a h22 timing map and it is totally different so i am going to go back tune again and see if i can get more torque. that was also on a stock h22 header with a large 2 inch collector
edit i am also using a p28 also
frostwhite_92
May 28, 2013 11:29 AM
raidacaipo
16
Nov 14, 2008 11:23 PM
vntperformance
May 20, 2003 05:03 AM
