Where do these wires go? *pics*
Old Sep 7, 2004 | 10:08 PM
0ptimus prime's Avatar
Default Where do these wires go? *pics*
Alright so i finished my cousin's CRX OBD1 D15b8 swap a while ago, just haven't had time to get all the little things done.
Alright, so i used his HF harness, OBD-0 injectors and all that good stuff. So here's the problems:
Since i used his HF harness, i have a left over connection, and i don't know what i'm supposed to re-wire it to.... here's the pic.
This is where these wires used to plug in on the OBD0 block just for reference.
Also, his OBD0 engine didn't have a thermo switch in the same location as the OBD1 engine, so i put a thermo switch in, but there's no harness connection for it...what do i do?
Old Sep 7, 2004 | 10:13 PM
Maddox's Avatar
The first pic is your thermo switch for OBD0, put a new plug on those wires and hook it up to that new thermo switch
Old Sep 7, 2004 | 10:15 PM
Default Re: (AllMotorCRX161)
sweetness, and from there it'll tell the fan when to turn on correct?
Oh and one more thing, can i use the CRX axles with the new obd1 engine? The driver side axle seems too long for this engine.
Old Sep 7, 2004 | 10:42 PM
Default Re: (0ptimus Prime)
bleh
Old Sep 7, 2004 | 10:49 PM
phan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0ptimus Prime &raquo;</TD></TR><TR><TD CLASS="quote">Oh and one more thing, can i use the CRX axles with the new obd1 engine? The driver side axle seems too long for this engine.</TD></TR></TABLE>
what tranny are you using?
Old Sep 7, 2004 | 10:51 PM
Default Re: (phan)
i'm using the OBD0 cable tranny, but the driver side axle (CRX axle) seems too long
Old Sep 7, 2004 | 10:57 PM
can somebody confirm that i need 90-93 integra axles in order to use the OBD0 cable tranny with the obd1 engine?
Old Sep 7, 2004 | 11:24 PM
crxgsr91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0ptimus Prime &raquo;</TD></TR><TR><TD CLASS="quote">sweetness, and from there it'll tell the fan when to turn on correct?
I always wondered what thoes went to.
I hooked my fan to a switched power so it runns all the time.
Old Sep 8, 2004 | 12:18 AM
turbo_ef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0ptimus Prime &raquo;</TD></TR><TR><TD CLASS="quote">can somebody confirm that i need 90-93 integra axles in order to use the OBD0 cable tranny with the obd1 engine?</TD></TR></TABLE>
well if u ran a single cam motor u just use the single cam axles.. u dont need the integra axles unless u are doing a b-series swap..
Old Sep 8, 2004 | 02:57 AM
shaddr3's Avatar
Default Re: (crxgsr91)
I hope you didnt wire it to constant supply....
Old Sep 8, 2004 | 04:00 AM
crx_88_si's Avatar
Default Re: (eli_vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eli_vang &raquo;</TD></TR><TR><TD CLASS="quote">
well if u ran a single cam motor u just use the single cam axles.. u dont need the integra axles unless u are doing a b-series swap..</TD></TR></TABLE>
not 100% accurate. it doesnt depend on the motor, depends on the tranny being used.
if you are using a Si/DX tranny the Si axles should work fine.
however, if u are using the ZC tranny w/ the Int shaft u will need 90-93 teg axles.
since the car is an HF, use HF Axles unless he has Si/DX/DA knuckles and hubs, then you would need to use a si/dx axle setup.
Old Sep 8, 2004 | 05:54 AM
slowpokesi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0ptimus Prime &raquo;</TD></TR><TR><TD CLASS="quote">can somebody confirm that i need 90-93 integra axles in order to use the OBD0 cable tranny with the obd1 engine?</TD></TR></TABLE> 90-93 axles will not work unless you have a intermediate shaft, and i seriously doubt that you do.
boomslang
Dec 6, 2010 09:37 AM
matmcg
Feb 17, 2008 12:46 PM
0ptimus prime
Sep 9, 2004 07:36 PM
0ptimus prime
Sep 7, 2004 11:32 PM
