turbo h22a stock
Old Sep 7, 2004 | 09:48 PM
H22A_HB
Guest
Posts: n/a
Default turbo h22a stock
if i would boost my h22a stock wut will happen to my motor and if its a good idea and how much boost should i run if it wont mess anything up
Old Sep 7, 2004 | 09:54 PM
preludeez's Avatar
Default Re: turbo h22a stock (H22A_HB)
this topic has been covered many times, search in this forum and you should be able to find more than enough information to answer your questions...
i wouldn't boost anymore than 8psi daily on a stock motor.
Old Sep 7, 2004 | 10:28 PM
H22A_HB
Guest
Posts: n/a
Default Re: turbo h22a stock (preludeez)
and if i boost it up to 8psi will in work find with out the motor ******* up
Old Sep 7, 2004 | 11:02 PM
sharkcohen's Avatar
Won't work well at all if it is not properly planned and tuned. Start doing some research. Don't buy a single part until you have a good understanding of what you are getting into. This will not only save your motor, but your pocketbook.
Old Sep 7, 2004 | 11:19 PM
H22A_HB
Guest
Posts: n/a
Default Re: turbo h22a stock (sharkcohen)
ok thanks
hondaaccord94
Apr 2, 2005 08:14 PM
GreenTeg
Oct 14, 2004 07:21 PM
H22aAccord
Jul 29, 2004 12:28 PM
RideAposition
Jul 14, 2003 12:06 AM
