HELP// Is this a 99 Si Brake Master Cylinder?
I just purchased a MBC/Booster/ Prop valve and the MBC has 7/8 stamped on it. I will be converting to 5 lug all around so is this the right MBC? The junkyard says it's off a 00 Si but I read somewhere that I need a 15/16 MBC. Please help!
damn that sucks, i had a feeling i got the wrong part. whats the difference between 15/16 and 7/8? can someone explain this? canadian si has rear disc too right? also can anyone tell how I can identify a Si prop valve? cause it doesn't really say much on on the prop valve either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoneyP »</TD></TR><TR><TD CLASS="quote">damn that sucks, i had a feeling i got the wrong part. whats the difference between 15/16 and 7/8? can someone explain this? canadian si has rear disc too right? also can anyone tell how I can identify a Si prop valve? cause it doesn't really say much on on the prop valve either.</TD></TR></TABLE>
Canadian SI = Usdm EX
You'll be fine with the 7/8 cylinder.
actually I've seen numerous Civic Si 99-00 have either the 7/8th M/C or 15/16 m/c I have no idea why but I have used both a 7/8 M/C and 15/16 on a 11"inch big brake kit and showed no difference between pressure of the pedal with either M/C
I am using my Stock Prop Valve on my 98 civic htbk.. and I run 11" fastbrakes front kit and rear 99-00si brakes..and have shown no ill effects with pedal pressure or any other problems ..plus I heard the Cx/dx model prop valve is identical to the 99-00SI prop valve.. but I do not know if the Ex model prop valve are the same..and my setup has seen a few days at streets of willows in 100+ degree weather
great.. does anyone have writeups on installing the booster? i hear it is difficult to install the booster. Anyone have info on this?
R6Boy69
Aug 15, 2006 01:59 PM
