Probably a dumb question...DOHC ZC...
Old Sep 7, 2004 | 07:34 PM
NorcalHB94's Avatar
Default Probably a dumb question...DOHC ZC...
Will a DOHC ZC swap right into a CRX? know they're made for 88-91 "civics" but does that include the CRX as well?
Old Sep 7, 2004 | 07:39 PM
2point2's Avatar
Default Re: Probably a dumb question...DOHC ZC... (NorcalHB94)
you can consider the CRX and Civic engine bays to be exactly the same.
Old Sep 7, 2004 | 07:44 PM
Starscream's Avatar
It's a direct bolt-in swap. The mounts are the same, and if you have an Si, it can bolts up to the Si tranny and you can use the Si harness.
Old Sep 7, 2004 | 07:58 PM
ServiceAdvisor's Avatar
Doesnt matter what tranny you have. Its any cable d-series transmission from any 89-91 CRX/EF8 will work. The DOHCZC is a direct drop in, just make sure your wired for MPFI if your a DX, HF/STD/Si's are direct drop in no other work necessary. Just two wires need to be extended from the Dizzy to the Crank Angle Sensor. Check http://www.thezcr.com for more info. - Darrell
Old Sep 7, 2004 | 08:19 PM
Rostr02's Avatar
Default Re: (DOHCZCCRXSi)
Old Sep 7, 2004 | 08:28 PM
nuc79's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCZCCRXSi &raquo;</TD></TR><TR><TD CLASS="quote">...HF/STD/Si's are direct drop in no other work necessary. Just two wires need to be extended from the Dizzy to the Crank Angle Sensor. </TD></TR></TABLE>
MPFI conversion needed for STD too (4spd MT, vinyl interior)
Old Sep 7, 2004 | 08:59 PM
ZacCarter's Avatar
better get a si tranny, not to thread jack or any thing, but luke i havent heard from you in a couple days where you been, did you get flooded out?
89crxsiVT
Apr 25, 2007 05:52 PM
89SilverCRX
Aug 13, 2006 03:10 PM
h22_crx
14
Sep 2, 2005 08:28 PM
the niz jiz
11
Sep 30, 2004 05:50 PM
paRRRker
Aug 7, 2002 07:40 AM
