need to find out if this ecu is an obd1 need help
ok im planning on buying this ecu from somebody on h-t. but the thing is that his friend gave it to him, so he doesn't know what kind of car it came out of exactly. i know it's a p75, but that's all i know
my question is from the code on the side of the ecu, can i find out if it is an obd-1 or obd-2 ecu. also if i can find out if it is from a manual or auto.
hopefully it's a obd-1 p75 that's manual
here's the code on the side
37820-p75-951
37820-p75-951
thanx that info helped alot.,
still need to find out if it is obd-1 or 2
here's a picture. sorry for the big size
Modified by knightnam at 10:34 PM 9/7/2004
still need to find out if it is obd-1 or 2here's a picture. sorry for the big size
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks »</TD></TR><TR><TD CLASS="quote">3 plugs obd1
4 plugs obd2
simple as that.....</TD></TR></TABLE>
Uhhh, actually 3 plugs means manual, 4 plugs means automatic...
OBD I ecu's only have 3 sections of plugs; OBD II ecu's have four sections, but only three of the sections have plugs, one is blank...
4 plugs obd2
I am trying to do a 90 crx dx to zc swap, and its an automatic I think I need an obd1 automatic ecu to do this swap, do you want to sell the one you have ?
You know, you can convert the ECU to manual. Search around for how to do it; I think it only involves moving a resistor around. Might be cheaper than finding a whole new ECU.. Just a thought.
Guest
Posts: n/a
