5 speed / automatic swap wiring
Old Sep 7, 2004 | 04:09 PM
93slmdcvcsi's Avatar
Default 5 speed / automatic swap wiring
i am currently working on a 95 Automatic LX, and I am converting to 5 speed. I was wondering if anyone knew what wiring changes needed to be made. That is the only thing holding me up. I just purchased the EG-AT tranny mount that I needed and I need some wiring instructions. If anyone can help I would gladly appreciate it. Thanks Guys (and girls)
Old Sep 7, 2004 | 04:16 PM
dantastic's Avatar
Default Re: 5 speed / automatic swap wiring (89cvchb)
https://honda-tech.com/zerosearch
put "auto swap" in the field and get this:
https://honda-tech.com/zerothread?id=550221
technology never ceases to amaze me
Old Sep 7, 2004 | 04:31 PM
Default Re: 5 speed / automatic swap wiring (dantastic)
i appreciate the help, but it doesn't tell me exactly what wiring changes need to be made.
Old Sep 7, 2004 | 04:38 PM
TRF #001's Avatar
someone correct me if im wrong but cant u just get the manual engine bay harness and the manual ecu and call it a day or is that only 96-00 ?? cuz i just did my 97 dx auto to manual and its running great.
Old Sep 7, 2004 | 04:43 PM
2fast4u831's Avatar
I'm really 2slow
I did my conversion early this year and all i did was leave the car in park the whole time with the auto gear selector. for the reverse lights im gonna try putting the gear selector in reverse and if it works ill just connect the two wires together and its solved,im 99.9% it will work
Old Sep 7, 2004 | 05:42 PM
coachkellum's Avatar
Default Re: (2FAST4U831)
it does work i took the two thick wires on the plug where the shifter is , thoses were the Nuetral safety switch, once thoses are connected you can start the car. but i am not sure what colors the reverse lights are.once you splice them together you will have reverse lights................
import-tooner
Sep 8, 2012 01:34 AM
str8drift
May 3, 2009 09:49 PM
ZAKU
Jun 30, 2008 06:50 PM
meric0786
Feb 18, 2008 03:03 PM
Carnut
Nov 26, 2003 08:01 AM
