450cc DSM Injectors in Non Boosted B18 ?
Old Sep 7, 2004 | 03:25 PM
slammedcivicsi's Avatar
Default 450cc DSM Injectors in Non Boosted B18 ?
Would it be a good idea to run the 450cc DSM injectors with a non boosed B18 swap in an ef ?.....just curious because I have some DSM injectors and am wondering if its going to cause any problems.
Old Sep 7, 2004 | 06:03 PM
Street Ghost's Avatar
Default Re: 450cc DSM Injectors in Non Boosted B18 ? (slammedcivicsi)
They will flood your motor. You won't be able to idle them without some sort of fuel management.
Old Sep 7, 2004 | 06:04 PM
Snail Tuning's Avatar
well it would flood your engine out because the stock injectors are 240 and u would be adding twice as much fuel as your stock injectors. now if u were to chip your ECU or use a vafc, then u could use the DSM injectors but i don't really see a need for those big of injectors in an n/a b18 unless your running 12:1:1 or higher comp, and its an all race engine
Old Sep 7, 2004 | 08:23 PM
just curious.....thanks for the info !
Old Sep 7, 2004 | 09:00 PM
Mag00n's Avatar
Default Re: (slammedcivicsi)
Overkill on a relatively stock motor....
thao0094
Jul 7, 2008 10:19 AM
ZERO COOL
Jul 15, 2002 05:36 PM
