Electrical Problems.... Need Help.
Old Sep 7, 2004 | 02:32 PM
98HB's Avatar
Default Electrical Problems.... Need Help.
Well I have been having the hardest time trying to figure out what my problem is. I have a 98HB DX with a H22 in it for the past three years and I never had a problem like this. I haven't changed anything in the car as of recently to make me think that I might have switched something on accident. I don't drive the car very often so once in a while I have to charge the battery to get it started, but I have done this before and never had any problems. So I went and bought a new battery and the car starts and runs fine for a couple of hours. Start it the next day and she starts but the battery is low and shuts off, so I go to the local shop and run a charging diagnostics and they tell me that my alternator is bad. So I go buy a new alternator and everything is fine for a day and the next day the same problem. So I figured I'll check my fuses with a volt meter and all the fuses in the car and under the hood are fine. I figured maybe it's my main relay, go to the Honda dealer and pick one up and put it in jump start the car and it starts fine the 5min. later I am losing all power and the cars shuts off?? Same thing happens again. Please someone help me out, I am about to sell this car.
Old Sep 7, 2004 | 06:36 PM
98HB's Avatar
Default Re: Electrical Problems.... Need Help. (98HB)
TTT
Old Sep 8, 2004 | 07:23 AM
98HB's Avatar
Bump
Old Sep 8, 2004 | 09:52 AM
Ekasey's Avatar
While the car is running place the DVOM on the battery terminals and read the voltage it should be above 13 V at idle and icnrease as you place more load on the engine.
Old Sep 11, 2004 | 06:21 AM
98HB's Avatar
Default Re: Electrical Problems.... Need Help. (eLusive ek4)
anyone else.
Old Sep 11, 2004 | 08:54 AM
Ekasey's Avatar
if you check that and tell me what it's doing i can offer some more solutions
mandalorianjedi
Dec 19, 2007 11:46 PM
Tearing-Away
Jan 9, 2007 04:40 PM
nivlak
Aug 1, 2005 06:28 AM
ID_ten_T
Nov 2, 2004 11:24 PM
