hit a curb today, cant tell whats wrong
Old Sep 7, 2004 | 02:30 PM
GroundZer0 336's Avatar
Default hit a curb today, cant tell whats wrong
i think its the bracket that holds the lca, but im not sure, its raining really bad so i havent had a chance to look at it.
but i was going around a curve goin like 40mph and my backend started comin around so i tried to correct it but just wasnt enough and my front left wheel hit the curb.
heres a pic. and i hurt my rim it scratched the lip up
Old Sep 7, 2004 | 02:36 PM
quicklilsi's Avatar
Default Re: hit a curb today, cant tell whats wrong (Optimus_primeR)
try checking where your front cross member bolts up to your sub-frame. i hit a curb in the snow and my tire was kicked into the back of the wheel well and it was the sub frame got bent.
Old Sep 7, 2004 | 03:04 PM
Default Re: hit a curb today, cant tell whats wrong (SPRCHRGDCRX)
so was your ish totalled from that or what, i think thats what happened to mine.
Old Sep 7, 2004 | 03:13 PM
CRX_Control's Avatar
ouch ,that doesnt look sexy
Old Sep 7, 2004 | 03:14 PM
Mr_CRX's Avatar
That happened to mine as well ... just not that bad.
Just yesterday I replaced the crossmember, sway bar, and LCA and it seems to have fixed it.
I'm not sure which one of those actually was the problem, but if anything, it was probably the crossmember. It was the only thing that was noticably tweaked, right where it bolts in on the drivers side. I'd pull it off and see how it looks. It's only like 4 bolts and then those two bolts on the radius rods.
Good luck
Old Sep 7, 2004 | 03:45 PM
daidilus's Avatar
Default Re: hit a curb today, cant tell whats wrong (Mr_CRX)
i did that exact thing you did...i have to replace my bent LCA, radius rod, and axle....then i was fine..
Old Sep 7, 2004 | 03:52 PM
PlastikOwl
Guest
Posts: n/a
Default Re: hit a curb today, cant tell whats wrong (daidilus)
be prepared to replace all of this ****...been there done that...your entire crossmember could be fucked like mine was...NOT fun...you'll then have to unbolt the steering rack, and the rear engine mount, and **** with the LCA and tie rods on the passenger side as well. Then you're going to need an alignment for sure...and the **** will probably never feel the same. Mine never did.
Edit: the "bracket" that holds the LCA is the entire front-rear lower crossmember.
4 bolts, you'll need to disconnect the steering rack from the column...undo the tie rods, and the LCA's as well as the rear engine mount. Have a friend handy because lifting that ****** back up there to bolt it back on when you get a new one is a real bitch. I barely managed it by myself doing a ******* acrobatic trick of holding up part of it with my leg while bolting the other side in, and I consider myself to be a fairly strong person. (I've broken sockets in half due to overtightening with a breaker bar before)
Check out the ******* BROKEN knuckle in the top right corner of this pic.
Radius rod snapped in two...had to get another one of those too.
Gee...which one is the normal one I wonder?
Modified by PlastikOwl at 5:03 PM 9/7/2004
Old Sep 7, 2004 | 04:17 PM
Default Re: hit a curb today, cant tell whats wrong (PlastikOwl)
okwell i got up under it and looked really good w/ my friend, seems that just the bracket that holes the lca on the crossmember is bent and the lca is bent,. the axle COULD be bent its hard to tell right now, but i think thats it. im gona take it apart tomorrow and look at each piece.
Old Sep 7, 2004 | 04:20 PM
PlastikOwl
Guest
Posts: n/a
the "bracket" is welded/built in to the crossmember. It's not a piece you can just take off. Look at the first picture I posted. Go to a junkyard and get another crossmember.
I can almost guarantee you won't be bale to bend it back into place either.
Old Sep 7, 2004 | 06:18 PM
daidilus's Avatar
problems with lifting back into place eh??? all you have to do is use a jack to jack up one side put one bolt in just enough to hold it, then go to the other side and repeat...then you can torque all the bolts properly
Old Sep 7, 2004 | 06:29 PM
SiR Inspired ED7's Avatar
Sucks man
Old Sep 7, 2004 | 06:41 PM
DOHC_EF's Avatar
I did the same to my car almost a year ago from now. Mine was not as nearly as bad as yours, but all that I did was a snapped radius rod and a bent LCA. But like I said yours is a lot worse than mine was.
Old Sep 7, 2004 | 06:42 PM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlastikOwl &raquo;</TD></TR><TR><TD CLASS="quote">the "bracket" is welded/built in to the crossmember. It's not a piece you can just take off. Look at the first picture I posted. Go to a junkyard and get another crossmember.
I can almost guarantee you won't be bale to bend it back into place either.</TD></TR></TABLE>
Dont even try to bend it back
Old Sep 7, 2004 | 07:20 PM
JnM4ev3r's Avatar
Default Re: hit a curb today, cant tell whats wrong (CRX_Control)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">ouch ,that doesnt look sexy </TD></TR></TABLE>
what he said
Old Sep 8, 2004 | 06:01 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
i did the same thing but not as bad. im in the same boat adn not really sure how i wanna go about doing it. my wheel didnt hit the curb thought, it was my toe hook.
Old Sep 8, 2004 | 06:06 AM
slowpokesi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlastikOwl &raquo;</TD></TR><TR><TD CLASS="quote">be prepared to replace all of this ****...been there done that...your entire crossmember could be fucked like mine was...NOT fun...you'll then have to unbolt the steering rack, and the rear engine mount, and **** with the LCA and tie rods on the passenger side as well. Then you're going to need an alignment for sure...and the **** will probably never feel the same. Mine never did.
i had to replace my rear subframe about 2 weeks ago, what a ******* bitch that was.
Old Sep 8, 2004 | 09:02 AM
PlastikOwl
Guest
Posts: n/a
Default Re: (daidilus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus &raquo;</TD></TR><TR><TD CLASS="quote">problems with lifting back into place eh??? all you have to do is use a jack to jack up one side put one bolt in just enough to hold it, then go to the other side and repeat...then you can torque all the bolts properly</TD></TR></TABLE>
I only had one jack
Just lifted it up there myself and cursed until the bolt lined up properly.
Old Sep 8, 2004 | 09:19 AM
ceLtic's Avatar
N/A wh0re!
what would prices for these parts go for?
Old Sep 8, 2004 | 09:25 AM
PlastikOwl
Guest
Posts: n/a
Default Re: hit a curb today, cant tell whats wrong (ceLtic)
I don't think I paid much more than 115 dollars at my local junkyard for all of those pieces...it was a few years ago so I can't remember all too well.
Old Sep 8, 2004 | 09:31 AM
slowpokesi's Avatar
i paid 65 for the cross member from a junkyard but i had to pull it myself.
Old Sep 8, 2004 | 09:37 AM
B16CRXT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Optimus_primeR &raquo;</TD></TR><TR><TD CLASS="quote">okwell i got up under it and looked really good w/ my friend, seems that just the bracket that holes the lca on the crossmember is bent and the lca is bent,. the axle COULD be bent its hard to tell right now, but i think thats it. im gona take it apart tomorrow and look at each piece.</TD></TR></TABLE>
So how does it look?
Old Sep 8, 2004 | 03:51 PM
Default Re: hit a curb today, cant tell whats wrong (B16CRXT)
didnt get a chance to do it today, spent the morning at the dentist then came back home just to watch the damn hurricane, its like flooding here. it sucks.
Old Sep 8, 2004 | 09:35 PM
stmizner's Avatar
what kind of driving conditions justify this? instantaneous flash flooding. learn to drive.
Old Sep 9, 2004 | 09:23 AM
Default Re: (stmizner)
uh, ok i can drive pretty damn good, this was an ACCIDENT. i hydroplaned and my back end came around. what could i do to stop this? besides not driving in the rain??? i was doing the speedlimit and i wasnt ******* around. so shut the hell up ******* noob.
Old Sep 9, 2004 | 09:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stmizner &raquo;</TD></TR><TR><TD CLASS="quote">what kind of driving conditions justify this? instantaneous flash flooding. learn to drive.</TD></TR></TABLE>
ur an ingnorant assclown
