H23 and nitrous
Old Sep 7, 2004 | 02:05 PM
92blackprelude's Avatar
Default H23 and nitrous
Want to get a little more power out of my h23 prelude and thought nitrous would be the best way to go......I was thinking about a zex dry kit. If i got a step colder plugs and retard the timing would it be really safe to run a 55 shot or 65? My engine has 160K miles on it but runs perfect never had any problems. Also is the zex "smart system" work very well. It sounds like it a good layout. Thanks for everything.
Old Sep 7, 2004 | 02:37 PM
Mario.'s Avatar
Default Re: H23 and nitrous (92blackprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92blackprelude &raquo;</TD></TR><TR><TD CLASS="quote">Want to get a little more power out of my h23 prelude and thought nitrous would be the best way to go......I was thinking about a zex dry kit. If i got a step colder plugs and retard the timing would it be really safe to run a 55 shot or 65? My engine has 160K miles on it but runs perfect never had any problems. Also is the zex "smart system" work very well. It sounds like it a good layout. Thanks for everything.</TD></TR></TABLE>
I loved my ZEX kit when I had it installed. It was a lot fun, I went through a bottle of nitrous a month, so money-wise it wasn't that bad. For the 55 and 65 shots, you don't have to retard any timing. For the ZEX kits, I'd run 1 step colder plugs. I ran this on my JDM b20a for a couple months, no complications. If you only gotta couple hundred but wanna get some speed I recommend it.
Old Sep 7, 2004 | 02:43 PM
SKDRCR's Avatar
Default Re: H23 and nitrous (Mario BA4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario BA4 &raquo;</TD></TR><TR><TD CLASS="quote">
. For the 55 and 65 shots, you don't have to retard any timing. : </TD></TR></TABLE>
i have to disagree with that, i would retard the ignition at least 2 degrees
the zex smart system should be good enough to add the proper fuel
to run a safe dry kit
i think your stock fuel pump should be fine with a 65 shot.
anything higher i would probably upgrade it though.
Old Sep 7, 2004 | 03:23 PM
SpyLude92's Avatar
Im runnin zex 55 on my SOHC F22 dropped 1 Sec easy off my 1/4 mile times, I have an H23 also. I think an H23 would love it. I was definately impressed, I recently pulled my f22 that had 4 bottles run through it, and you couldn't tell it had even seen nitrous. on ZEX You will enjoy the feel.
Old Sep 7, 2004 | 03:25 PM
Default Re: H23 and nitrous (SpyLude92)
any worries about my 160000 miles on my car? also how do i retard the timing on an h23 do you think 2-3 degrees would be good........i know you have to go about working with the distributor. Is there any write-ups on this. thanks.
Modified by 92blackprelude at 4:52 PM 9/7/2004
Old Sep 7, 2004 | 04:08 PM
DarkBB4's Avatar
also interestd here, i have a h22 (129k)
would you reccomend a dry or WET kit?
Old Sep 7, 2004 | 05:03 PM
SpyLude92's Avatar
The engine i ran 4 tanks through, has 157,600 on it. To adjust timing loosen the 3 distributor bolts, clockwise to retard, and counterclockwise to advance.
Old Sep 7, 2004 | 08:06 PM
Mario.'s Avatar
You don't have to retard anything for a 55 shot. I guess you do for a 65. So my statement was partially correct.
Old Sep 7, 2004 | 08:50 PM
Uncle Fester's Avatar
Default Re: H23 and nitrous (DarkspeedVtec95)
I would go with a wet kit. It doesnt have the hit a dry kit does, but its a lot safer because the Zex system is feeding it more fuel from the return line. Ask for the retard, with a 65 shot or less you wont need it as long as the fuel is there to burn.
Old Sep 8, 2004 | 08:13 AM
BoostedH23Accord's Avatar
Default Re: H23 and nitrous (Uncle Fester)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpyLude92 &raquo;</TD></TR><TR><TD CLASS="quote">The engine i ran 4 tanks through, has 157,600 on it. To adjust timing loosen the 3 distributor bolts, clockwise to retard, and counterclockwise to advance.</TD></TR></TABLE> Make sure you use a timing light to know where your advancing your motor. The last thing you want to do is loose power because of too much retard. (No pun intended) If you dont know what your doing I suggest you find a friend who can show you the ropes. When your working with something like N20 you don't want to make careless mistakes. Granted a 55 shot or 65 shot for that matter wont do much damage but you want to be careful when spraying nitrous. The Zex dry kit is a great kit for beginners I used to go through about 4 tanks a month (track time included) with the 65 shot.
Good luck
Old Sep 8, 2004 | 01:21 PM
Default Re: H23 and nitrous (BoostedH22Accord)
Well i will just have to get someone else to help me with it that has a timing light
I was also wondering what is safer......the wet or the dry kit and what you guys prefer on your cars.....if one or the other is safe why? thanks
Modified by 92blackprelude at 2:43 PM 9/8/2004
Old Sep 8, 2004 | 03:02 PM
fastludeh22's Avatar
n2o is a good cheaper way. first you need to do a leak down and compression test. do all normal maintance...ie-plugs, wires, cap, rotor, anything that looks worn.
that will work, but you lose a little off the bottle. if you get a msd digi 6, you can only drop timing during spray. that way you can advace a few degrees on the dist. for performance, and compansate using the msd.
Old Sep 8, 2004 | 04:49 PM
SUB-0 H23's Avatar
a 65 shot (flywheel rated) of nitrous is safe, no biggie... i would recommend u to get a DP system if u plan on using a larger shot of n2o... see the link in my sig to check out my dyno plot on a 60 shot (flywheel rated)...
Old Sep 8, 2004 | 08:34 PM
ICreamOnNi$$an
Guest
Posts: n/a
haha nitrous
Old Sep 9, 2004 | 08:05 AM
eLUDEnu
Guest
Posts: n/a
Default Re: H23 and nitrous (ICreamOnNi$$an)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICreamOnNi$$an &raquo;</TD></TR><TR><TD CLASS="quote">haha nitrous</TD></TR></TABLE> STOP POST WHOREING!!!!
I have just installed a zex dry kit on my car with a 75 shot. as soon as I get my trans In I will let you know what I think.
ArmaanOG
Mar 11, 2009 10:22 AM
D.A.luder
Feb 17, 2005 04:07 PM
BLACK_DEL_SOL
Aug 17, 2004 04:44 PM
SKDRCR
Oct 4, 2003 05:53 AM
MiddleSchllBlwoz
Feb 25, 2003 06:54 PM
