VTEC not working....?
I dont know what happened but VTEC isnt working..... hmmm anyone?
*EDIT*
found out that the gasket was cover with gunk. Got new one, VTEC worked for a bit then later on the CEL is on and VTEC isnt working...... HELP!!!
Modified by H.A.R.T B16AEG6 at 1:33 AM 9/11/2004
Modified by H.A.R.T B16AEG6 at 1:36 AM 9/11/2004
*EDIT*
okay well pulled the head out to do some work on it.... put it back on. Then I had a OBD1 dx ecu because i let a friend use my skunk P28. Just got the P28 back and floored it..... and nothing. It just redlined to 8 and i didnt even hear VTEC at all or even feel. The car felt like it was struggling going to 8.... now anyone?
Yeah i am really good on oil... and no i didnt just plug it in and go. I gave it lots and lots of time. So i really dont know....
There is a oil filter screen (in the head?) to protect the Vtec components, if the screen is clogged there won't be enough oil pressure to make the VTEC work.
Also check the VTEC solinoids. GL
cels?
Did you let the car warm up? It won't go into Vtec till its warmed up.
Did you plug everything back up?
Check your grounds by your Vtec Pressure Sensor, and solenoids.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B16AEG6 »</TD></TR><TR><TD CLASS="quote">What is CEL?</TD></TR></TABLE>
First of all your an idiot. Did you even read what Archidictus wrote??? what exactly was done to the head? and you should even be working on a car if you dont know what a Check Engine Light is.
Why dont you take it back to the place that pulled off your head in the first place and tell them it isnt working because it sounds like you shouldnt be touching it.
Check the connections to your vtec solenoid (cylinder right by the distributor) I had my swap done and the clip came lose and i lost vtec so just check that first and if that doesn't work you might be low on oil and it can't build oil pressure.
okay well my CEL didnt come on at first. Found out that the VTEC solenoid gasket was blocked with gunk. Got a new gasket. VTEC worked perfect. Okay now I just came home from driving and now the CEL is on now and my VTEC doesnt work and it seems like the car is having a hard time getting to redline.
Im gonna go and get the CEL checked..... but everytime i turn the car off the CEL is gone, until i floor it to about 7000rpms. Then the CEL comes on.
