Heads up for nice Type R brake rotors
Old Sep 7, 2004 | 01:24 PM
Big Phat R's Avatar
Default Heads up for nice Type R brake rotors
Hi all,
I thought I would pass along some info about some east-coast manufacturer of upgraded brake rotors for the Type R and other Hondas.
I saw a set a friend of mine bought for his STi and they looked nicey nice! They're heat treated and dynamically balanced - a little better than the Autozone crap - and probably a better choice for peeps that are REALLY hard on their brakes.
Check them out:
http://www.racingbrake.com/index.html
BPR - who is waiting to see if they come in 93-94 Legend GS/LS Coupe size because he wore his pads down to the backing plates at the track yesterday
Old Sep 7, 2004 | 01:30 PM
Willard's Avatar
Default Re: Heads up for nice Type R brake rotors (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">They're heat treated and dynamically balanced - a little better than the Autozone crap</TD></TR></TABLE>
:shrugg:
I guess you need that stuff.
Wonder what the price will be.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">and probably a better choice for peeps that are REALLY hard on their brakes.</TD></TR></TABLE>
I am 'sorta' hard on my brakes... and autozone crap works fine for me.
wear items = need to be cheap.
Old Sep 7, 2004 | 01:38 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Slotted and drilled =
Old Sep 7, 2004 | 01:45 PM
Big Phat R's Avatar
Default Re: (Rguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy &raquo;</TD></TR><TR><TD CLASS="quote">Slotted and drilled = </TD></TR></TABLE>
Yeah I know....
I wasn't really looking at that - more the heat treating and surface finishing.
The STi ones I saw were slotted - not drilled.
I get hotspots on cheap rotors - seems to be related to quality of the rotor iron more than pad material (actually seems to get worse with the more aggressive track pads).
- I guess I'll have to try a set and post a review.
BPR - who goes through rotors like diapers
Old Sep 7, 2004 | 02:09 PM
white rocket's Avatar
They look really nice. I bought a complete brake kit(Slotted/Drilled rotors, metal master pads, ss lines, ATE racing fluid) for a helluva deal from c rotors in the performance section. Just waiting for them to arrive. They are zinc coated, don't know about heat treated though. My car doesn't see the track. Yet. If these don't work out, I'll give these a try.
By the way, BPR, your R is amazing. Looks like Vancouver in the background in your pic. Wish I could of seen it in person at the Type R meet back at the beginning of August.
Old Sep 7, 2004 | 02:48 PM
Bbasso's Avatar
Price???
Old Sep 7, 2004 | 03:12 PM
fso_BamBam's Avatar
New User
Default Re: (Big Phat R)
A review would be nice. Unfortunately, I'm already seeing cracks on the OEM Brembo blanks I've been using for only 2 track days. Usually, rotors last me about 3-4 track days, but maybe without realizing it, I'm too hard on my brakes.
If these things last a bit longer, all the better. I think at $40/rotor, the brembos are starting to eat away at my wallet at this rate.
Old Sep 7, 2004 | 03:22 PM
sackdz's Avatar
Default Re: (fso_BamBam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fso_BamBam &raquo;</TD></TR><TR><TD CLASS="quote">I'm too hard on my brakes.
No such thing, your brakes are too *****!
I suffer from teh same thing
Heat cracks genereally after 2 days on AUtozone rotors.
At 2500lbs w/driver and ducts I still fade both Pather XP's and Cobalt spec VRs easily within 10 laps at Gingerman if I try.
The addition of ducting helped a lot, I think when I get a little more direct airflow on the brakes the problem should be not so bad.
Old Sep 7, 2004 | 05:50 PM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">I get hotspots on cheap rotors - seems to be related to quality of the rotor iron more than pad material</TD></TR></TABLE>
how can cast iron be made that differently?
spots = pad/use issue vs. iron quality IMO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">Heat cracks genereally after 2 days on AUtozone rotors.
cracks = a given with enough heat.
ducting will help the 2 day issue .... buy 'any' rotor will get heat cracks with enough time.
http://www.we-todd-did-racing....x.jpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fso_BamBam &raquo;</TD></TR><TR><TD CLASS="quote">I think at $40/rotor, the brembos are starting to eat away at my wallet at this rate.</TD></TR></TABLE>
$24.95 autozone rotors = cheaper.
Old Sep 7, 2004 | 05:55 PM
Kengs's Avatar
Default Re: (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">
Ahem
Those are AP-Dixcel in case you're wondering
Old Sep 7, 2004 | 05:56 PM
BlueR's Avatar
Default Re: (kengs)
:slapsforehead:
leave it up to shane
Old Sep 7, 2004 | 06:00 PM
Willard's Avatar
Default Re: (kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">Ahem </TD></TR></TABLE>
jdm cast iron does not count.
Old Sep 7, 2004 | 08:58 PM
Lo-Buck EF's Avatar
a friend of mine actually works closeley with the racing brake folks in teh development of their subaru line. hence the slotted ones that there trying to get to full blanks. they are necessary on subaru because the stock rotor material is very soft for some reason. they do make for tons of other applications and i think they make blanks for itr as they first made rotors for show room stock and improved touring hondas. i know they make a couple differant material rotors. their top of the line turns cool colors in the bedding in process. the only reason i havent tried them is they only make cross drilled/slotted in my application and i've already broken autozone rotors. check out the site and e-mail them they'll be happy to answer your questions.
-spenc
Old Sep 7, 2004 | 09:33 PM
spoolindc2's Avatar
i have had no problem whatsoever w/ my brembo slotted/drilled rotors and ive gone thorugh 2 sets of pads w/o any cracks... i might not be as hard on my brakes as a race car driver but damn they r still holding up .....
Old Sep 7, 2004 | 09:35 PM
vactor's Avatar
Default Re: (spoolindc2)
too bad stoptech stopped (sic) making the aerorotors for the R. i heard nothing but good things about them from users.
Old Sep 7, 2004 | 09:40 PM
slammed_93_hatch's Avatar
Default Re: (vactor)
im useing some power stop (re-boxed brembo's, its got 'brembo thesome part number) on the side. these rotor are drilled, im VERY hard my bakes, no ducting and no fading, no crackes yet either
Old Sep 8, 2004 | 02:37 AM
.RJ's Avatar
.RJ
Default Re: (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">im VERY hard my bakes, no ducting and no fading, no crackes yet either</TD></TR></TABLE>
I doubt you are as hard on brakes as me and Will. I suck at them, but I did get 5 weekends out of my last set of XP8's and autozone rotors.
Old Sep 8, 2004 | 03:15 AM
- Sim -'s Avatar
Default Re: (.RJ)
why dont you get rotora discs? if for oem size they look similar.
or better - like I have - 4 piston brake system from rotora. best choice of weight and brake power i think.
Old Sep 8, 2004 | 03:36 PM
Lo-Buck EF's Avatar
Default Re: (- Sim -)
Willard + the shute at slummit=glowing rotors in broad daylight
hockeyMike2489
Oct 31, 2006 06:24 AM
Archidictus
Suspension & Brakes
54
Aug 12, 2005 09:54 PM
ScareyH22A
Honda Motorcycles
11
Jul 12, 2005 06:57 PM
advanracing62
Mar 28, 2004 02:24 PM
