Will a 88 CRX SI tranny fit onto a 89 CRX SI?
My tranny went out for my 89 CRX SI. I'm planning to buy this 88 CRX SI tranny but I don't know if it will fit. The guy doesn't know too. I've heard that 88-89 have the same tranny, and the 90-91 has a different one. I don't know. Please help
No, the 88 is the outcast. I believe you have to use the 88 flywheel and clutch to make it work, not sure what else though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">No, the 88 is the outcast. I believe you have to use the 88 flywheel and clutch to make it work, not sure what else though. </TD></TR></TABLE>
you got it
you got it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fresnodx »</TD></TR><TR><TD CLASS="quote">thanks!! do you know anyone selling?</TD></TR></TABLE>
Selling what, crack?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fresnodx »</TD></TR><TR><TD CLASS="quote">My tranny went out for my 89 CRX SI. I'm planning to buy this 88 CRX SI tranny but I don't know if it will fit. The guy doesn't know too. I've heard that 88-89 have the same tranny, and the 90-91 has a different one. I don't know. Please help
88 and 89 Si use the same flywheel - you need 88 clutch disc
</TD></TR></TABLE>88 and 89 Si use the same flywheel - you need 88 clutch disc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fresnodx »</TD></TR><TR><TD CLASS="quote">So can I use the 89 pressure plate and a 88 tranny and disc?</TD></TR></TABLE>
Yup.. With either a 88-89 flywheel..
The only difference between the 88-89 trannies is the spline count on the input shaft..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">No, the 88 is the outcast. I believe you have to use the 88 flywheel and clutch to make it work, not sure what else though. </TD></TR></TABLE> well said VAP. Had the same problem you member member.
CRX_GUY_123
May 31, 2004 05:24 AM
firstgenrex
Jan 25, 2004 10:23 AM
tgreaves
Dec 3, 2003 01:14 PM
