What is an intake temp. sensor????????
Old Sep 7, 2004 | 12:16 PM
clos0821's Avatar
Default What is an intake temp. sensor????????
I have code 10 popping up and i looked it up and it says its the intake temp. sensor. Where is that sensor? (I have obd1, ls/vtec on a 92 cx hatch.)
Old Sep 7, 2004 | 12:46 PM
crx_88_si's Avatar
Default Re: What is an intake temp. sensor???????? (clos0821)
usually on the side of the drivers most side intake manifold runner.. little white sensor.
Old Sep 7, 2004 | 04:48 PM
TRF #001's Avatar
Default Re: What is an intake temp. sensor???????? (crx_88_si)
u sed its ls/vtec right. if u can find out what engine harness is used or if vtec is just hardwired in and what intake manifold it might be because if its the b16/ gsr /R manifold, then theres no spot for on there because its located in the intake tube. but if there is one on the manifold, its where crx 88 si sed, on the back and its a lil white plug with 2 wires
bringmyownend
Dec 16, 2010 08:25 PM
chinewalker
Oct 1, 2009 04:25 PM
EF4lyfe
Sep 20, 2004 12:00 PM
blackeg
Sep 14, 2004 01:39 AM
