Engine light on, gas mileage low...
Old Sep 7, 2004 | 04:47 AM
ITR0952's Avatar
Default Engine light on, gas mileage low...
I added some more oil other day, and few days later i went and start the car.... the car first started to shake a little bit.. then I realize the engine light won't turn off. it is yellow right now..... I haven't check the ECU... don't really know how.
What do u think might be wrong with it? it is hard to guess.... cause I did add 1/3 of a quart to it. It's my LS. i thought put it here cause R ppl tend to be more mechanical knowledgable.
Thanks.
Old Sep 7, 2004 | 04:48 AM
Philly_NBP_R's Avatar
Default Re: Engine light on, gas mileage low... (ITR0952)
if you don't know how to check the ecu codes, bring the car to someone who does (like the dealer).
Make sure that you didn't overfill the oil also...
Old Sep 7, 2004 | 07:39 AM
DragII's Avatar
25 Year Member
pull the code then post back...it could be anything until you do that. If you don't know how to pull the code, search the archives for how to do it, or take your car to a shop and have them do it.
Old Sep 7, 2004 | 09:55 AM
Mugen Mike's Avatar
http://www.c-speedracing.com/faq/06.php
Old Sep 7, 2004 | 03:01 PM
ITR0952's Avatar
Default Re: Engine light on, gas mileage low... (Mugen Mike)
Thanks guys
I check the ECU, it is 71
71 for
94+ Integra
Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
what's that?
The car pretty much drive normal, but MPG is decreasing.. Does it mean it only using 3 cyclinders?
Modified by ITR0952 at 4:25 PM 9/7/2004
Old Sep 7, 2004 | 03:04 PM
emotionisdead's Avatar
Very Emergency!!
i could be a number of things. could be a faulty map sensor dumping to much fuel, a fouled spark plug, a sticking injector, could be a ignition or fuel delivery fault.
Old Sep 7, 2004 | 03:05 PM
ITR0952's Avatar
Default Re: Engine light on, gas mileage low... (Booyakasha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Booyakasha &raquo;</TD></TR><TR><TD CLASS="quote">i could be a number of things. could be a faulty map sensor dumping to much fuel, a fouled spark plug, a sticking injector, could be a ignition or fuel delivery fault. </TD></TR></TABLE>
That sounds bad... damn, I was about to sell the car....
I really don't wanna put any money into it...I guess I can't avoid spend money?
Modified by ITR0952 at 4:46 PM 9/7/2004
Old Sep 7, 2004 | 03:15 PM
Propulsion's Avatar
when was the last time you changed the plugs? pull the plugs, check it, then check the plug wire (w/ a multimeter if you have one), then replace the cap/rotor. Start w/ the inexpensive stuff.
Old Sep 7, 2004 | 03:29 PM
spyderracing's Avatar
Default Re: Engine light on, gas mileage low... (SilverCIVIC96)
May be O2 sensor aswell.... bad gas mileage.
Old Sep 7, 2004 | 04:32 PM
94civicEX's Avatar
Replace the spark plug in cylinder one, then go from there.
Old Sep 7, 2004 | 06:15 PM
Default Re: (94civicEX)
check and/or replace the following if necessary:
plugs
wires
distributor cap & rotor
reset ecu, then go from there. These parts are cheap - go to your local dealer, or acuraautomotiveparts.net for a good deal...
Old Sep 8, 2004 | 03:00 AM
ITR0952's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicEX &raquo;</TD></TR><TR><TD CLASS="quote">Replace the spark plug in cylinder one, then go from there.</TD></TR></TABLE>
Can anyone show pic of where the spark plugs are?
Old Sep 8, 2004 | 03:15 AM
DutchITR1689's Avatar
Default Re: (ITR0952)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR0952 &raquo;</TD></TR><TR><TD CLASS="quote">
Can anyone show pic of where the spark plugs are?</TD></TR></TABLE>
I think you should bring it to a shop....
Old Sep 8, 2004 | 05:27 AM
NAstreetEH2
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR0952 &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone show pic of where the spark plugs are?</TD></TR></TABLE>
that is a joke....right?????
i'm not a huge itr fan...but, ya know...you shoudl have it revoked from you...AND the LS
Old Sep 8, 2004 | 06:14 AM
ITR0952's Avatar
Default Re: (NAstreetEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAstreetEH2 &raquo;</TD></TR><TR><TD CLASS="quote">
i'm not a huge itr fan...but, ya know...you shoudl have it revoked from you...AND the LS</TD></TR></TABLE>
Everyone has their first times... don't think you are borned to know everything... I actually learned quite a bit on this board because of so many helpful people... I know i am coming little slow.. but i will get there eventually. If you just gonna laugh at people. shouldn't even bother to post a reply to my mesg.
Old Sep 8, 2004 | 06:49 AM
opkjoblacsh's Avatar
but honestly you came on so smart sounding then you said you didnt know where the ecu was ok? understandable. but honestly if you dont know where the spark plugs are you dont need to have the hood up i mean its dangerous under there it could fall on you. haha jackass
Old Sep 8, 2004 | 04:39 PM
NAstreetEH2
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR0952 &raquo;</TD></TR><TR><TD CLASS="quote">Everyone has their first times... don't think you are borned to know everything... I actually learned quite a bit on this board because of so many helpful people... I know i am coming little slow.. but i will get there eventually. If you just gonna laugh at people. shouldn't even bother to post a reply to my mesg. </TD></TR></TABLE>
even my grandma knows where the spark plugs are.....
i've NEVER heard ANYONE have to ask that, that actually has a car. maybe a 3rd grader.
Old Sep 8, 2004 | 06:19 PM
Black R's Avatar
25 Year Member
.....iirc my bad mileage problem and CEL came from bad primary o2 sensor.
If you are getting less than 220 miles per tank, replace the primary o2 sensor.
torqueless
Acura TL, RL & ZDX
Mar 31, 2005 04:02 PM
BigMig
May 10, 2003 06:01 PM
Train
Apr 30, 2003 07:14 PM
SuPeRITR
Mar 18, 2003 06:02 PM
civicracer1993
Apr 18, 2002 06:57 PM
