question about my V.C. Gasket... needs answering
Old Sep 7, 2004 | 03:56 AM
Mike1486's Avatar
Default question about my V.C. Gasket... needs answering
I open my hood and do my usual inspection and sure enough i come to discover that my valve cover gasket is sweating . has this happened to any one? can anyone tell me if this is serious or not? perhaps maybe i just need a new valve cover gasket cause the one i have is old? all comments are welcomed of course...
Old Sep 7, 2004 | 04:09 AM
ipleadthe5th's Avatar
Photoshop Guru
Default Re: question about my V.C. Gasket... needs answering (Mike1486)
thats never happened to me but I'd replace it along with the gromets. You can get it for like $25 from honda
Old Sep 7, 2004 | 08:04 AM
Mike1486's Avatar
Default Re: question about my V.C. Gasket... needs answering (ipleadthe5th)
but can somone name tha cause for the VC gasket to be sweating? i mena n e major problems that maybe associated with that? or just age?
Old Sep 7, 2004 | 08:59 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
sweating, you mean oil leaking?
Old Sep 7, 2004 | 09:48 AM
Mike1486's Avatar
Default Re: question about my V.C. Gasket... needs answering (PatrickGSR94)
ok i dont know much about mechanics.... i just know where stuff is but as far as its purpose im clueless what is ur valve cover gasket supposed to do? what systems does it work with?
Old Sep 7, 2004 | 12:35 PM
97TegraLS's Avatar
The valve cover allows access to the components of your cylinder head (valves, valve adjusters, cams, etc.). The gasket makes the seal between the valve cover and the cylinder head. On the Integra engines the valve cover gasket is a rubber ring that gets inserted into a channel on the valve cover where it meets the cylinder head. They are less than $10, and easy to change. Just get a 10mm socket on a 2" extension on a ratchet, and you’re done.
It may be that the bold backed out and loosened up. Try tightening them first, and degreasing the engine, and monitoring the seeping of oil. If it persists, just replace it.
Old Sep 7, 2004 | 05:26 PM
Mike1486's Avatar
Default Re: question about my V.C. Gasket... needs answering (97TegraLS)
thanks man that really helped out ill keep in touch with you for n e more situations LoL
foowitdaredek
Mar 6, 2015 01:44 PM
caliskier
Mar 22, 2009 04:45 PM
touandcim
13
Dec 29, 2007 09:46 AM
jackiebenware
Oct 28, 2005 05:31 PM
darkfx
Oct 8, 2005 09:51 AM
