What suspension and brake parts differ from the LS to GSR?
Old Sep 6, 2004 | 10:07 PM
Demon_Dub's Avatar
Default What suspension and brake parts differ from the LS to GSR?
Just like title says, Im also wondering if there are any other performance related pars that come standard on the GSR but not on the LS. Aside from the motor
Old Sep 6, 2004 | 10:22 PM
migs's Avatar
Default Re: What suspension and brake parts differ from the LS to GSR? (Demon_Dub)
Tranmission is different. I believe the suspension including the swaybars are the same.
Old Sep 6, 2004 | 10:27 PM
DC2*Integra's Avatar
Default Re: What suspension and brake parts differ from the LS to GSR? (migs)
swaybars are different. LS sway bars are thinner than GSR sway bars.
Old Sep 7, 2004 | 08:43 AM
Demon_Dub's Avatar
Default Re: What suspension and brake parts differ from the LS to GSR? (DC2*Integra)
Other then that its all the same for the most part?
Old Sep 7, 2004 | 08:58 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demon_Dub &raquo;</TD></TR><TR><TD CLASS="quote">Other then that its all the same for the most part?</TD></TR></TABLE>
Everything is the same other than the swaybars, on the earlier G3's. Later G3's had the same front swaybar across the board, including ITR's. I'm not sure if the later years had different rear swaybars or not between GS-R and non-VTEC models.
Old Sep 7, 2004 | 09:21 AM
dip-set's Avatar
Default Re: What suspension and brake parts differ from the LS to GSR? (PatrickGSR94)
i believe in 96 is when the front sway bar went from 22mm to 24mm,and 97 is when the rear went from 13mm to 14mm,cause i just changed the bracket bushings for my swaybars,and the front was 24mm after i ordered the 22mm bushing went to install it and realized it was 24mm,used the 22mm bushing anyway..but the rear in fact was 13mm..
is there a negative effect in using the 22mm swaybar bracket bushing on a 24mm swarbar?
Old Sep 7, 2004 | 11:16 AM
Demon_Dub's Avatar
Default Re: What suspension and brake parts differ from the LS to GSR? (b18b-se)
Right on guys thanks. Im surprised the brakes are the same.
Spawne32
Apr 5, 2010 02:56 PM
HondaGSX
Jan 23, 2007 07:51 PM
Drian
Jan 2, 2006 08:47 AM
idriveadelsol7
Apr 20, 2005 07:40 PM
ckyguy
Suspension & Brakes
Feb 21, 2005 07:55 AM
