'90 CRX HF [Brakes]
i basically salvaged this dude from the junk yard....and first thing ima do is the suspention...ive been thinking about koni adjustible struts/shocks, and skunk 2 lowering springs along with skunt 2 cambers and power slot slotted rotors.....i read on here something about how HF's have to have something changed or what? or does that apply to me? any help/opinions is appreciated! also, does this set up sound ok?
if you havent noticed im a noob
-walt
-walt
if you want better brakes my advice would be to use da integra stuff it bolts up its bigger and more effective and you dont have to worry about changing crap out for aftermarket stuff to work...
just rember if u run the DA knuckles, ur going to have to run DX/Si axles, because the hubs on the DA/DX/Si's are bigger....but if u were planning on running a swap u were going to have to do this anyway...
