My vtec is not kicking in
Old Sep 6, 2004 | 07:30 PM
EF4lyfe's Avatar
Default My vtec is not kicking in
I swapped a sohc jdm d15b vtec into 90 si hatch, everything is fine except vtec is not kicking in, i am running the p08 ecu which is the stock ecu for that motor. I am getting code 7 which is TPS, throttle position sensor, could this be causeing vtec to not kick in? yes i did do the obd0 to obd1 conversion.
Old Sep 7, 2004 | 09:58 AM
B16 CRX's Avatar
Default Re: My vtec is not kicking in (SIhatch90)
you may also want to check the oil pressure switch , TPS is one of the problems as well, because my VTEC wouldnt open either due to TPS, I replaced it with the oil pressure swith now it opens up just fine
Old Sep 7, 2004 | 10:00 AM
MENACE's Avatar
Default Re: My vtec is not kicking in (B16 CRX)
If youre throwing that Code VTEC Will not Come on.
Old Sep 7, 2004 | 11:04 AM
rjay8604's Avatar
Default Re: My vtec is not kicking in (MENACE)
one time i didn't sleep all night and stayed up and i felt like i was tripping on coke or something, i remember i couldn't tell if vtec was kickin in or not, i was tying it while delivering chinese, make sure you've slept. sorry lol, just thought i bring some positive feeling to the problem.
Old Sep 7, 2004 | 04:52 PM
EF4lyfe's Avatar
thanks everyone, that is def funny
MugeNinja
Dec 29, 2005 09:50 AM
Excelerate
Jun 17, 2005 06:55 AM
dkboyny11
Jun 2, 2005 03:45 PM
danteisme
Sep 26, 2004 03:19 PM
Hondasaurs
May 9, 2003 08:51 PM
