Need help on oil leak please
Old Sep 6, 2004 | 07:00 PM
93sleeper's Avatar
Default Need help on oil leak please
Ok i replaced the valve cover gasket and the oil pan gasket. But turns out its the front engine seal, the one behind the crank. Now how much will honda probly charge to do this fix and does the engine have to be removed.
Old Sep 6, 2004 | 07:10 PM
SUB-0 H23's Avatar
Default Re: Need help on oil leak please (93sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sleeper &raquo;</TD></TR><TR><TD CLASS="quote">Ok i replaced the valve cover gasket and the oil pan gasket. But turns out its the front engine seal, the one behind the crank gear Now how much will honda probly charge to do this fix and does the engine have to be removed.
no the engine does not have to be removed.. u would probably want to change the timing belt and water pump ect..
Mr_maxime
Jul 10, 2016 08:04 PM
Kyle700
Jan 18, 2015 04:57 PM
blacktibby07
Feb 16, 2011 11:45 AM
blurry454
Jul 28, 2009 09:29 AM
srburk
Feb 6, 2005 04:35 AM
